Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: CHRISTIAN END on 02-09-2009 08:56:18 AM Hello, i worked on a script with PHP that sets a CFA for a directory number and a special state of the user for this phone in a MySql DB. On my CUCM 7 in the office it works fine. It also works fine on a CUCM 6.1.2 for a few days. But now i get this error messages in the AXL Trace... I hope someone can help me!!! This is only one of the Requests and errors... This request was for NO CFA.
2009-09-02 08:00:04,815 INFO [http-8443-Processor22] axl.AXLRouter - Received request 1248944066632 from AXLadmin at IP 53.101.17.68 2009-09-02 08:00:04,938 INFO [http-8443-Processor22] axl.AXLRouter - <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Body><axl:updateLine sequence="1234" xmlns:axlapi="http://www.cisco.com/AXL/API/1.0" xmlns:axl="http://www.cisco.com/AXL/API/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.cisco.com/AXL/API/1.0 axlsoap.xsd"><UpdateLineReq><pattern>777</pattern><callForwardAll><destination></destination></callForwardAll></UpdateLineReq></axl:updateLine></SOAP-ENV:Body></SOAP-ENV:Envelope> 2009-09-02 08:00:05,042 ERROR [http-8443-Processor22] axl.AXLRouter - com.cisco.ccm.axl.AXLRouter@1af7dad java.sql.SQLException: Can't load driver java.lang.reflect.InvocationTargetException at com.informix.util.IfxErrMsg.getLocSQLException(IfxErrMsg.java:494) at com.informix.jdbc.IfxDriver.connect(IfxDriver.java:271) at java.sql.DriverManager.getConnection(DriverManager.java:525) at java.sql.DriverManager.getConnection(DriverManager.java:193) at com.cisco.ccm.dbl.Connector.getConn(Connector.java:663) at com.cisco.ccm.dbl.Connector.connect(Connector.java:580) at com.cisco.ccm.dbl.Connector.connect(Connector.java:510) at com.cisco.ccm.dbl.Connector.createStatement(Connector.java:751) at com.cisco.ccm.dbl.Connector.createStatement(Connector.java:733) at com.cisco.ccm.axl.AXLThrottler.getNodeNames(AXLThrottler.java:223) at com.cisco.ccm.axl.AXLThrottler.getClusterInformation(AXLThrottler.java:89) at com.cisco.ccm.axl.AXLThrottler.getThrottlingCount(AXLThrottler.java:145) at com.cisco.ccm.axl.AXLRouter.checkThrottleStatus(AXLRouter.java:487) at com.cisco.ccm.axl.AXLRouter.doPost(AXLRouter.java:161) at javax.servlet.http.HttpServlet.service(HttpServlet.java:709) at javax.servlet.http.HttpServlet.service(HttpServlet.java:802) at sun.reflect.GeneratedMethodAccessor2954.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:243) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:517) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:275) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:161) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:245) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:50) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:156) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:152) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:524) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:541) at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:392) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869) at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684) at java.lang.Thread.run(Thread.java:595) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27) at java.lang.reflect.Constructor.newInstance(Constructor.java:494) at com.informix.jdbc.IfxDriver.connect(IfxDriver.java:254) ... 42 more Caused by: java.sql.SQLException: INFORMIXSERVER does not match either DBSERVERNAME or DBSERVERALIASES. at com.informix.jdbc.IfxSqliConnect.<init>(IfxSqliConnect.java:971) ... 47 more Caused by: com.informix.asf.IfxASFRemoteException: at com.informix.asf.Connection.recvConnectionResponse(Connection.java:600) at com.informix.asf.Connection.establishConnection(Connection.java:1488) at com.informix.asf.Connection.<init>(Connection.java:261) at com.informix.jdbc.IfxSqliConnect.<init>(IfxSqliConnect.java:906) ... 47 more
Subject: RE: AXL / java.sql.SQLException Replied by: David Staudt on 02-09-2009 12:34:29 PM I believe this error indicates that the AXL service could not connect to the UCM database. If the request is being sent to a UCM subscriber node, ensure that the publisher node is up and running, and that the cluster configuration is correct.
Subject: RE: AXL / java.sql.SQLException Replied by: CHRISTIAN END on 03-09-2009 01:10:31 PM I point the AXL request to the publisher. I try to restart the machines. Possible that there is something stuck in the system.
