cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Dave Goldberg on 30-01-2011 05:52:49 AM
The customer has 2 Tandberg HD cams connected into his C60.  I am trying to give him a camera preview on his touch panel.  I am trying to do this by hooking up the composite output (3) of the C60 to the composite video input of the touch panel.  When they select the far end camera, I reset to default layouts so that composite output 3 shows the far end to the touch panel.  After I do that, I try to preview a camera, but the camera will not display again on the tp preview window unless I select the other camera.  Then it switches back and forth just fine.  As soon as I reset the layouts, the same thing happens.  When I can't get the camera to display, I just get a black screen on my preview.  I have attached the api code I am sending via 232.  Any ideas?
DEFINE_CALL 'CAMERA_1 TO TP'
OFF[dvCODEC,VTC_PRES_FULL_SCREEN]
SEND_COMMAND aryTP_13,"'^BMF-33,0,%Tfull|screen'" // Rev xxx - 3
WAIT 5
SEND_STRING dvCODEC,"'xCommand Video Layout Add',$0D"
WAIT 10
SEND_STRING dvCODEC,"'xCommand Video Layout Frame Add LayoutId: ',ITOA(nLayoutID),' Layer: 5 PositionY:0                      VideoSourceId: 1 PositionX: 0 Height: 10000 Width: 10000 Border: On VideoSourceType: localInput',$0D"
WAIT 15
SEND_STRING dvCODEC,"'xCommand Video Layout AssignLocalOutput OutputId: 3 LayoutId: ',ITOA(nLayoutID),$0D"
DEFINE_CALL 'CAMERA_2 TO TP'
WAIT 5
WAIT 10
SEND_STRING dvCODEC,"'xCommand Video Layout Frame Add LayoutId: ',ITOA(nLayoutID),' Layer: 5 PositionY: 0 VideoSourceId: 2 PositionX: 0 Height: 10000 Width: 10000 Border: On VideoSourceType: localInput',$0D"
WAIT 15
DEFINE_CALL 'FAR END TO TP'
// SEND_STRING dvCODEC,"'xCommand Video Layout UnAssignLocalOutput OutputId: 3 LayoutId: ',ITOA(nLayoutID),$0D"
                    SEND_STRING dvCODEC,"'xCommand Video Layout Reset',$0D"
// WAIT 3
// SEND_STRING dvCODEC,"'xCommand Video Layout Removeall',$0D"
// WAIT 6
// SEND_STRING dvCODEC,"'xCommand Video Layout Frame Add LayoutId: "1" Layer: "1" PositionY: "0" VideoSourceId: "24" PositionX: "0" Height: "10000" Width: "10000" Border: "On" VideoSourceType: "remoteMain"',$0D"
// WAIT 9
// SEND_STRING dvCODEC,"'xCommand Video Layout Assign OutputId: "3" LayoutId: "1" CallId: "1"',$0D"
DEFINE_CALL 'FULL SCREEN VTC LOCAL PRESENTATION'
ON[dvCODEC,VTC_PRES_FULL_SCREEN]
SEND_COMMAND aryTP_13,"'^BMF-33,0,%Texit full|screen'" // Rev xxx
WAIT 3
WAIT 6
SEND_STRING dvCODEC,"'xCommand Video Layout Frame Add LayoutId: "1" Layer: "5" PositionY: "0" VideoSourceId: "3" PositionX: "0" Height: "10000" Width: "10000" Border: "On" VideoSourceType: "localInput"',$0D"
WAIT 9
SEND_STRING dvCODEC,"'xCommand Video Layout Assign OutputId: "1" LayoutId: "1" CallId: "1"',$0D"
Can what I am trying to do even be done?  Is there something unique about composite output 3?  I remember in the past being told that you could never get the on-screen-menus to show up on that output.  Is that still the case?  There is a setting in the on-screen configuration that dictates the monitor role of output 3.  Could that somehow be preventing me from doing what I am trying to do?  I tried a bunch of different things.  I ended up settling on layer 5 because I thought maybe some black layer was on top and that is why I couldn't see the camera layer.  I also tried using the "'xCommand Video Layout UnAssignLocalOutput OutputId: 3 LayoutId: ',ITOA(nLayoutID),$0D" but that didn't change anything.  The problem is only when you first come back from displaying the far end (wallpaper since I was not doing these tests in an active call).  Also, another interesting thing I noticed while testing was this; before I knew how to use the layouts properly, I would just create a layout number of my own choosing (not the number given back when doing "'xCommand Video Layout Add',$0D").  It seemed like it took it and accepted it.  If I tried to create that same number layout again before deleting it, I would get an error.  But it still seemed like it would let me create a lyout number of my choosing.  Also, in the API guide, for xCommand Video Layout UnAssign, it mentions something about an audio command:
"OutputId: A unique identifier for the local output, which was created when the xCommand Audio
LocalOutput Add command was issued."  Could the fact that I am not issuing any audio command have anything to do with my problem?
Subject: RE: C60 TC4.0.0 custom layout problems
Replied by: Scott Stanley on 31-01-2011 10:09:48 PM
I am working on doing exaclty the same thing.
Reading your post it was like the one I was getting ready to write.  Glad you beat me to it.
I am anxious to hear a response from Tandberg.
I will post if I find soluiton.
Replied by: Scott Stanley on 01-02-2011 03:04:30 AM
I have been playing with your code.  I noticed you are redrawing the layout each time you call it.  As you know (I learned from you) each time you Video Layout Add the LayoutId is incrementing.
I setup one call to save the layouts.  This is your code.  I just added PASSTHRU= to work with my module.
To keep my testing simple I am Video Layout RemoveAll before I initialize the layouts.  I know there is likely a downside and will continue to explore what is going on.
DEFINE_CALL 'INIT_CONFERENCE_LAYOUTS'
sEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout RemoveAll',$0D"
nLayoutID=1
WAIT 5
SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout Add',$0D"
WAIT 10
SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout Frame Add LayoutId: ',ITOA(1),' Layer: 5 PositionY:0 VideoSourceId: 3 PositionX: 0 Height: 10000 Width: 10000 Border: On VideoSourceType: localInput',$0D"
nLayoutID=2
WAIT 5
WAIT 10
SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout Frame Add LayoutId: ',ITOA(2),' Layer: 5 PositionY: 0 VideoSourceId: 2 PositionX: 0 Height: 10000 Width: 10000 Border: On VideoSourceType: localInput',$0D"
I route to the two inputs as follows:
DEFINE_CALL 'TANDBERG_CAMERA_1_TO_TP' (nLayoutID)
SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout AssignLocalOutput OutputId: 3 LayoutId: ',ITOA(1),$0D"
DEFINE_CALL 'TANDBERG_CAMERA_2_TO_TP'(nLayoutID)
SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout AssignLocalOutput OutputId: 3 LayoutId: ',ITOA(2),$0D"
DEFINE_CALL 'TANDBERGC60_FAR_END_TO_TP'
SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xCommand Video Layout Reset',$0D"
This works reliably switching between the inputs.  If I ever execute CALL 'TANDBERGC60_FAR_END_TO_TP' then  I have to CALL 'INIT_CONFERENCE_LAYOUTS' to get it to call the inputs again.
Replied by: Viggo Fredriksen on 03-02-2011 12:16:03 PM
The last example is pretty close, but it shouldn't be necessary to execute Video Layout Reset if you want the default layouts for the composite output. I would've used UnassignLocalOutput instead:
1DEFINE_CALL 'TANDBERGC60_FAR_END_TO_TP'
2{
3    SEND_COMMAND vdvCODECA_COMM,"'PASSTHRU=xcommand Video Layout UnassignLocalOutput OutputId: 3',$0D"
4}
If you're using the TANDBERG supplied AMX module, I would also take a look at the included Tandberg_TC_VideoLayoutAPI.axi.
Replied by: Dave Goldberg on 04-02-2011 05:48:59 PM
At one point during the testing, I tried using UnassignLocalOutput and that did not fix the issue.  I am not using the AMX module or include file.
