cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Gerald Knight on 22-02-2013 08:46:19 AM
Is there a good doc/ detail on C90 MIC mixer settings? This would be where you want the 8 MICs to mix input during calls from people in the C90 room during TelePresence calls; of course one can set levels, echo cancellation and such, but a little more on suggested settings, whether MICs will mute below a certain level, AGC, etc. Thanks! Would also be interested in some detail of OSD so customer can make minor tweaks, etc.
Subject: RE: C90 audio mix and tweaks
Replied by: David Bruun-Lie on 26-02-2013 08:42:03 AM
Hi Gerald, are you using TC Console to do the audio mixing? If not I recommend that you download that application first from this site. Apart from that application I don't know of any documentation on the level you are requesting.
Regarding OSD there is a limited set of tweaks you are able to to. They are documented in the integrator guide for the C90. Anything specific you are after?
Cheers,
David
Replied by: Gerald Knight on 26-02-2013 08:51:08 AM
Hi David,
Thanks.
I was talking abount TC Console with one of our leads, so yes, will plan on using it.
Don't think we need anything fancy, but in a conference room would like to make sure that the MICs are balanced and that they mute correctly during calls to minimize background noise at positions where no one is speaking.
