Geevarghese Cheria
Introduction.
This document discuss about some of the issues that occur when calling across SIP Trunk and  solution for the same.
Problem
you have a SIP trunk on CUCM connecting to a remote system. When ever you receive an inbound call on a PRI
and send the call to the SIP trunk, the SIP trace is sending sip:[email protected] to the remote system.
you want this to be send with an IP address so the call will not be rejected.
Topology
PRI > Cisco Voice GW > CUCM >  CUCM SIP TRUNK > remote system.
Solution
CUCM sends calling number as anonymous@anonymous over SIP, because you receive the calling party type as 'private' on the SIP Trunk.
So CUCM is behaving as expected.  Here what you need is to come up with a workaround is to have the CUCM pass this
information.  The most straightforward solution would be to convert the incoming Gateway to H323 and put a Translation Rule on the Gateway to change the Calling Party Type.
  • Reproduce the problem and then get the call manager traces.
  • Note the calling number, the called number, call manager ip and the remote system
After Analyzing the traces following steps were done to resolve the issue. Since, the last CLI governing connection was the SIP Trunk on SIP Trunk,
  • Enable Transmit UTF-8 for Calling Party Name
  • Change Calling Party Selection: From Originator to First Redirect Number
  • Calling Line Id Presentation: From Default to Allowed
  • Calling Name Presentation: From Default to Allowed
Problem
You have a  CUBE and SIP trunk for PSTN calling. Here Your outbound calls work fine, but inbound calls are failing.
You had an original block of inbound DIDs that are working  fine but a new block of them is not working.
Topology:
ITSP - - [SIP] - - CUBE - - [SIP] - - CUCM
Solution
In debugging it was found that the new block of DIDs was 917-647-24XX. This was matching the ITSP facing dial-peer
which was set for 9.T instead of the CUCM facing dial-peer.  That dial-peer was stripping the 9 off the call and sending
it back to the PSTN.
So to fix this issue you need to make another more specific dial-peer for that block with no digit stripping
and sends the call to CUCM.  This will work correctly and will not adversly affect anything.
Problem
Incoming and outgoing calls to cube are not working
Topology:
NET UX2000 >> SIP Trunk >> CUBE >> SIP Trunk >> CUCM >> IP Phone
Solution
In genereal following are the steps that need to be performed to resolve the issue:
  • Configure a bind command under dial-peers to CUCM.
  • Add  css to sip trunk
  • Use a translation rule to  send 4 digits to cucm
  • For outgoing calls add the  ip addresses to trust list under voice service voip
Here since you have two sip trunk providers on the same cube and the calls that are using a 9 to route outbound calls works fine.
You are dialing the numbers directly for eg, 2xxxxxxxxx or 7xxxxxxxxx. Here you need to use
an 8 for access to the SIP trunk that connects cucm.
  • To accomplish this update the route pattern with 8.@ and no prefix strip
Also update the  cube config with the following
voice translation-rule 100
rule 1 /^8/ //
voice translation-profile Strip_8
translate called 100
dial-peer voice 9001 voip
description INBOUND CUCM to CUBE
session protocol sipv2
incoming called-number 8.
voice-class sip profiles 1
dtmf-relay rtp-nte h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 9002 voip
destination-pattern 8T
session target ipv4:155.203.48.9
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
translation-profile outgoing Strip_8
Problem
Router is not registering with service provider
Topology:
CUCM ---- H323 ---- 2951 ---- SIP ---- ITSP
Solution
Here in this case the ideal scenario would be
Router        ITSP
REGISTER
100 TRYING
401 UNAUTHORiZED (www-authenticate: challenge presented)
REGISTER (www-authenticate: response to challenge)
200 OK
Router 2951# show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
81[2-9]..[2-9]......          352        107          no
8[2-9]......                    351        107          no
9043833521                 -1          145          no
Following is the o/p from debugs:
REGISTER sip:10.255.255.5:5060 SIP/2.0
Via: SIP/2.0/UDP 209.156.51.26:5060;branch=z9hG4bK5C822
To: <sip:[email protected]>
Date: Tue, 18 Sep 2012 04:02:37 GMT
Call-ID: 86BD5D87-7111E2-8002B6E5-A1B39CB6
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1347940957
CSeq: 28 REGISTER
Contact: <sip:[email protected]:5060>
Expires:  3600
Supported: path
Content-Length: 0
000522: Sep 18 00:02:37.745: //97/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
To: <sip:[email protected]>;tag=aprqngfrt-p1qqhk00000o1
CSeq: 28 REGISTER
To resolve this issue Contact the Service Provider and they told to REGISTER message with different IP address.
To accomplish this you need  bind the SIP traffic with a different interface (Ex GigabitEthernet0/0.2).
Problem
All the inbound/outbound calls are failing.
Solution
Collected debug output from CUBE found when CUBE has never received any 100Trying or
180Ring message from CUCM for inbound call, it appears CUCM has never respond any SIP
invite.
<snip>
91   22:59:27.322 INVITE 2586123269466 W->
244  22:59:27.338 <-------------100 Trying
258  22:59:27.342                         INVITE 6123269466 W/ S->
296  22:59:27.434                         INVITE 6123269466 W/ S->
334  22:59:27.634                         INVITE 6123269466 W/ S->
457  22:59:28.042                         INVITE 6123269466 W/
SDP----------------------->
495  22:59:28.142                         INVITE 6123269466 W/
533  22:59:28.342                         INVITE 6123269466 W/
598  22:59:28.750 <----408 Request Timeout
613  22:59:28.774 ACK-------------------->
636  22:59:28.850
<--------------------------------------------INVITE 2586123269466 W/ SDP
789  22:59:28.866                         100
Trying------------------------------------------------------------->
803  22:59:28.866                         INVITE 6123269466 W/
SDP-------------------------------------------
<snip>
Reviewed CUCM ccm Trace, found CUCM in fact did respond 100Trying and 180Ring message
back to CUBE.   But the messages have never reached to the CUBE.
<snip>
0.97.222.123---------CUCM----------------10.97.222.123-----------10.97.222.123-----------1
0.97.222.123-----------10.97.222.123-----------10.97.222.123-----------10.97.222.123------
-----10.97.222.123
1611  23:29:47.299 INVITE 6123269466 W/ S->
1689  23:29:47.301 <-------------100 Trying
1987  23:29:47.311 <------------180 Ringing
2017  23:29:47.397 INVITE 6123269466 W/ S->
2068  23:29:47.398 <------------180 Ringing
2099  23:29:47.597 INVITE 6123269466 W/ S->
2150  23:29:47.598 <------------180 Ringing
2442  23:29:48.451 <----------200 OK W/ SDP
2504  23:29:48.840                         <-INVITE 6123269466 W/ S
2582  23:29:48.841                         100 Trying------------->
2877  23:29:48.851                         180 Ringing------------>
2905  23:29:48.933                         <-INVITE 6123269466 W/ S
2956  23:29:48.934                         180 Ringing------------>
2985  23:29:48.962 <----------200 OK W/ SDP
3029  23:29:49.134                         <-INVITE 6123269466 W/ S
3080  23:29:49.134                         180 Ringing------------>
3187  23:29:49.974 <----------200 OK W/ SDP
<snip>
Further troubleshooting it was  found that there is a sip binding command that binds to out side interface of the router,
while CUCM has also configured router out side interface for the SIP trunk.
As a result CUCM did not really respond 100Trying and 180ring message back to CUBE (enabled
SIP binding on ISR1 would caused issue while there are separated network for internal and
external).
To resolve this
  • Remove sip binding command from voice service
  • Change the CUCM SIP trunk IP address to CUBE's internal IP.
Related Links
No voice when calls accross SIP Trunk
