Andrew Fox
I am having some problems setting the Default User Locale in Cisco Unity Connection. I have gone in to "System Settings" "Enterprise Parameters" and changed teh "Default Network Locale" to United Kingdom however I cannot change "Default User Locale" from English United States. When I select the pull down box the only option I have is English United States. Does anyone know how I can fix this?
A00460610
Did you ever solve this, I have the same issue, I can change the user language but not the default user locale in enterprise parameters,
