cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Rand Dusing on 29-06-2009 03:00:23 PM
Can CIP images contain color or are they only limited to 2 bit color depth?  Are CIPs only used for the 7940 and 7960 non-color phones?
Rand
Subject: RE: CIP Images
Replied by: David Staudt on 29-06-2009 06:30:57 PM
CIP does not support color - color images can be accomplished using the .png abilities of the xxxFile (i.e. CiscoIPPhoneImageFile) objects, on the phones that support them.  Note that all the phones support CIP images, some support .png also.
Replied by: Rand Dusing on 29-06-2009 06:45:31 PM
Thanks for the confirmation, I was afraid this was true.
