TCC_2
Level 10
Level 10
Core Issue
The annunciator is used for Session Initiation Protocol (SIP) ring back. So, the SIP Trunk needs to have a media resource group list (MRGL) that contains the annunciator or the annunciator needs to be in the default list. Otherwise, no ring back is received.
Resolution
In order to fix this issue, add the existing annunciator media resource group (MRG) to all the remote MRGLs.
Cisco CallManager uses Skinny Call Control Protocol (SCCP) messages in order to establish a Real-Time Protocol (RTP) stream connection between the
annunciator and the device. The annunciator plays the announcement or tone in order to support these conditions:
  • Announcement Devices configured for Cisco Multilevel Precedence Preemption
  • Barge tone Before a participant joins an ad hoc conference
  • Ring back tone When a call is transferred over the Public Switched Telephony Network (PSTN) through a Cisco IOS  gateway
    The annunciator plays the tone because the gateway cannot play the tone when the call is active.
  • Ring back tone When calls are transferred over an H.323 intercluster trunk
  • Ring back tone When calls are transferred to the SIP client from an SCCP phone
So the annunciator can play a ring back tone, a call is transferred over the PSTN through a Cisco IOS  gateway.
Refer to Understanding Session Initiation Protocol (SIP) for more information:
