This is here to help those of you to get Cisco Jabber to work in a VMware horizon view environment with non-persistent linked clones.
1.
Add DNS records for Cisco Jabber.
Create DNS records for the following names on your domain DNS server
Service: _cuplogin
Protocol: _tcp
Priority: 0
Weight: Your Choice (If you have a DR you will have to create two records and weight accordingly)
Port Number: 8443
Host: IM and Presence server FQDN
Service: _cisco-uds
Protocol: _tcp
Priority: 0
Port Number: 8443
Host: Call Manager server FQDN
Cisco Document on DNS for Jabber.
2.
Edit GPO for Persona Management
Add Policy
Files and Folders to Preload
AppData\Roaming\Cisco\Unified Communications\Jabber\CSF
3.
Turn on the auto start on the jabber client
When you first enter your info check the box for:
Sign me in when Cisco Jabber starts
Then once jabber loads click on file and options. And under general place a check in:
Start Cisco Jabber when my computer starts.
