cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: FRANK JONG on 11-12-2009 01:37:00 PM
In the SDK Quick Start guide the following document is mentioned:
Cisco
Unified CME Call Control/Monitor API specification (reference guide)
Where is this API specification located?
I can find the Cisco Unified Communications Manager Express Call Monitoring Interface Guide, but it dates from 2007.
(http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_technical_reference09186a008085f708.html)
Subject: RE: CME Call Control/Monitor API specification
Replied by: Yawming Chen on 11-12-2009 04:08:10 PM
Hi Frank,
the link you provided is not for this SDK.
Unified CME Call Control/Monitor API specification (reference guide) refers to JAVA Doc is in http://developer.cisco.com/c/document_library/get_file?folderId=1621717&name=DLFE-24402.zip  zip file in
http://developer.cisco.com/web/ucxapi/resources
Replied by: FRANK JONG on 14-12-2009 04:08:21 PM
Hi Yawming,
Thank you for your reply.
I think it answers the question, but it was not what I was looking for.
I thought the mentioned reference guide specified the underlying CSTA interface.
Because we don't use Java in our main development (and we already can use CSTA), we would like to know the events/operations implemented by cisco and extensions they created in the CSTA interface.
Kind regards,
Frank
Replied by: Yawming Chen on 14-12-2009 04:49:37 PM
Yes that Java doc specify all the API classes which is based on ECMA Computer Supported Telecommunications Applications (CSTA) and TR-87standards.
What language are you using for development ?
Yawming
Replied by: FRANK JONG on 16-12-2009 09:06:29 AM
We develop in C++.
Because we already build a CSTA stack in C++ we would like to use this stack instead of rebuilding all features to Java.
Frank
Replied by: Yawming Chen on 16-12-2009 03:41:10 PM
I am sorry to say that unfortunately there is no C++ API now.
Yawming
