TCC_2
Community Member
Core Issue
The Communication Media Module (CMM) dial-in with the Voice Extended Markup Language (VXML) script fails if it is not loaded correctly or is corrupt.
Resolution
In order to fix the issue, complete these steps:
  1. Reload the script.
  2. Remove the "+" and "-" symbols in the VXML script.
Note: Although VXML is added in Cisco IOS  Software Release 12.2(11), these software releases have VXML issues and must not be used:
  • Cisco IOS Software Release 12.3(8)
  • Cisco IOS Software Release 12.3(9)
  • Cisco IOS Software Release 12.3(14)T1
  • Cisco IOS Software Release 12.2(15)
Refer to the Configuring H.323 Gateways for Mobile Voice Access section of Cisco Unified MobilityManager Installation Guide for more information.
