This document was generated from CDN thread
Created by: Dan Giesen on 14-04-2011 09:06:42 PM
Is it possible to us the Compositor Tool to send 2 camera feeds to 2 displays at a remote location? And, can the remote codec (C60 or C90) send 2 camera feeds to 2 displays at the near end at the same time? This would create a 2 screen 2 camera telepresence (immersive) experience.
Thanks for your feedback.
Dan.
Subject: RE: Compositor and Dual Monitors
Replied by: Jonas Tysso on 15-04-2011 10:47:10 AM
Hi Daniel
When compositing two camera feeds into one stream it is not possible to "decompose" the stream on two displays on far end. However you can achieve what you want by using the dual stream for the second camera instead of a presentation source. Notice that the dual stream is limited to 30 fps.
Cheers,
Jonas
