vivkalra
Level 2
Level 2
CoPP - Control Plane Policing
Definitions:
  • Control Plane (CP): A collection of processes that run at the process level on the route-processor (RP). These processes collectively provide high-level controls for most IOS functions.
  • Central Switch Engine: A device that is responsible for high-speed routing of IP packets. It also performs high-speed input and output services for non-distributed line cards.
  • Distributed Switch Engine: A device that is responsible for high-speed routing of IP packets on distributed line cards without using resources from Central Switch Engine.
  All packets that are destined for CP must pass through the Central Switch Engine before they are forwarded to the process level. The CP and Central Switch Engine are part of the Route Processor (RP).
Overview:
The Control Plane Policing feature allows users to configure a QoS filter that manages the traffic flow of control plane packets to protect the CP of Cisco IOS routers and switches against various attacks like Denial-of-Service (DoS).
The CoPP feature treats the CP as a separate entity with its own input and output ports. Hence a set of rules can be established and associated to the input and output ports of the CP. These rules are only applied if the packets are destined for the CP or they exit from the CP.
Input CP services are executed after input port services and a routing decision on the input path have been made. CP security and packet QoS are applied on-
  1. Aggregate CP Services: An aggregate level by the Central Switch Engine and applied to all CP packets received from all line cards on the router
  2. Distributed CP Services: A distributed level by the Distributed Switch Engine of a line card and applied to all applied to all CP packets received from all line cards on the router.
Types of packets forwarded to CP:
The following L3 packets are forwarded to the CP and processed by aggregate and distributed control plane policing-
  1. Routing protocol control packets
  2. Packets destined for the local IP address of the router
  3. Packets from management protocols like SNMP, Telnet & SSH.
CoPP Configuration:
All Telnet traffic with source address 1.1.1.1 is allowed without constraint, however, any remaining Telnet traffic is policed at the specified rate.
CoPP Configuration
ip access-list extended CoPP_traffic
deny tcp host 1.1.1.1 host 2.2.2.2 eq telnet ! Allow this traffic unconstrained
permit tcp any any eq telnet                 ! Rate-limit this traffic
class-map Telnet_class
match access-group name CoPP_traffic
policy-map CoPP_policy
class Telnet_class
  police cir 8000
   conform-action transmit
   exceed-action drop
control-plane
service-policy input CoPP_policy
When a Telnet connection is initiated to 2.2.2.2 with source address 10.1.1.1, it matches the access-list and policing is imposed upon the traffic since the source address is not 1.1.1.1
debug ip packet detail
IP: s=10.1.1.1 (Serial0/0), d=2.2.2.2, len 44, rcvd 4
     TCP src=60033, dst=23, seq=2907233763, ack=0, win=4128 SYN
IP: s=2.2.2.2 (local), d=10.1.1.1 (Serial0/0), len 44, sending
     TCP src=23, dst=60033, seq=3862546484, ack=2907233764, win=4128 ACK SYN
IP: s=10.1.1.1 (Serial0/0), d=2.2.2.2, len 40, rcvd 4
     TCP src=60033, dst=23, seq=2907233764, ack=3862546485, win=4128 ACK
The
show policy-map control-plane is used to display the service-policy associated to the control-plane. It also shows the packets that matched the class-map. This can be verified using
show access-list command too.
Policy-map verification
R2# show policy-map control-plane
Control Plane
  Service-policy input: CoPP_policy
    Class-map: Telnet_class (match-all)
      62 packets, 2866 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name CoPP_traffic
      police:
          cir 8000 bps, bc 1500 bytes
        conformed 62 packets, 2866 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
        conformed 0 bps, exceed 0 bps
    Class-map: class-default (match-any)
      38 packets, 2944 bytes
      Match: any
R2# show access-list
Extended IP access list CoPP_traffic
    10 deny tcp host 1.1.1.1 host 2.2.2.2 eq telnet
    20 permit tcp any any eq telnet (62 matches)
