cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Saeed Ahmed on 03-03-2010 08:52:20 PM
I want to receive FAX on router and want to run tcl script which should run on router and that IVR will play and ask for verification code e.g( wellcome to cisco systems if you like to send fax please dial your personal code) as the code press the fax get received or if  the code is worng play IVR again or disconnect.
how can i accomplish this solution.can any one help me to make a script of that or is it any other way out to deploy this soluiton
Subject: RE: Create XML TCL script for FAX on-ramp
Replied by: Skylar Jeffries on 18-05-2010 01:03:42 PM
Believe you can start with the management interface which helps administrators manage scripts on Cisco routers. There are many powerful scripts available that you can test and learn from and then write your own.  The TCL IVR infrastructure is enhanced with the addition of support for MGCP using the application model and MGCP defines application packages to run scripts on the
media gateways. Good luck!
Skylar
Inexpensive Online Fax
Cheapest Business VoIP Phone
