06-30-2015 12:16 AM - edited 03-12-2019 10:16 AM
Introduction
This document covers the procedure for configuring Destination Dial peer groups.
Dial-peer grouping feature. A group of dial-peers can be made a part of a dial-peer group under a “voice class dpg <tag>”
“destination dpg <tag> will be used to reference a dial-peer group  from an incoming dial-peer
Once an incoming dial-peer is matched. The dial-peers which are a part of the dpg defined under it will be used for outbound dial-peer matches on the particular call.
(config)#voice class dpg <tag>
(config-class)#dial-peer <dial peer tag> preference <preference number>
Dial peer group configuration
Step 1: Incoming Dial peer is first matched
Device(config)# dial-peer voice 100 voip
Device(config-dial-peer)# incoming called-number 1341
Device(config-dial-peer)# destination dpg 10000
Device(config-dial-peer)# description DP Source Boston w/voice class dpg
Device(config-dial-peer)# end
Device(config)# end
Step 2: Now the DPG associated with the Inbound DP is selected ie dpg 10000 is selected in the above configuration
Grouping outbound dial peers and configuring preferences needed.
Device(config)# voice class dpg 10000
Device(config-class)# dial-peer 1001 preference 1
Device(config-class)# dial-peer 1002 preference 2
Device(config-class)# dial-peer 1003
Device(config-class)# description voice class DPG for DP Source Boston
Device(config-class)# exit
3. Outbound DP is selected based on the above configuration
Configuring outbound Dial peers
Device(config)# dial-peer voice 1001 voip
Device(config-dial-peer)# destination-pattern 1001
Device(config-dial-peer)# session protocol sipv2
Device(config-dial-peer)# session target ipv4:10.1.1.1
Device(config-dial-peer)# exit
Device(config)# dial-peer voice 1002 voip
Device(config-dial-peer)# destination-pattern 1002
Device(config-dial-peer)# session target ipv4:10.1.1.2
Device(config)# dial-peer voice 1003 voip
Device(config-dial-peer)# destination-pattern 1003
Device(config-dial-peer)# session target ipv4:10.1.1.3
Verify
Show voice class dpg <tag>
Ex. CUBE#show voice class dpg 10000
Voice class dpg: 10000      AdminStatus: Up
 Description:
 Total dial-peer entries: 4
 Peer Tag           Pref
 1                  0
 2                  0
 104                0
 1000               0
Troubleshoot
Debug voip dialpeer can be used for debugging to identify the DPG selected and the list of dial-peers under the DPG that match the destination pattern.
*Jul 19 10:15:53.311 IST: //-1/ED647BD1B0F9/DPM/dpMatchPeersCore:
   Outbound Destination DPG Group Request; Destination DPG=21
*Jul 19 10:15:53.311 IST: //-1/ED647BD1B0F9/DPM/dpMatchDestDPGroup:
   Result=0
   Result=SUCCESS(0) after DestDPGroup
*Jul 19 10:15:53.311 IST: //-1/ED647BD1B0F9/DPM/dpMatchSafModulePlugin:
   dialstring=244510104, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jul 19 10:15:53.311 IST: //-1/ED647BD1B0F9/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=104
     2: Dial-peer Tag=1000
     3: Dial-peer Tag=102
     4: Dial-peer Tag=101
     5: Dial-peer Tag=104
Hi Muthurani,
Looks like the document got edited and fell short of the complete description.
Could you please add some more description to it?
Hi Muthurani,
Once the outbound DP is selected within a DPG, is the command "destination-pattern" used?
I mean, is there any other matching mechanism processed at the outbound DP level, to confirm this DP can really be used? (like "destination-pattern", or "voice class e164-pattern-map")
This part is not clear in the docs.
Thank you.
Yorick,
When an inbound dial-peer is bound to an outbound dial-peer using dpg the destination-pattern is not used for matching. The destination-pattern is still required to be configured.
show dial-peer voice | inc destination - this will show the dpg tag and validity
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/multiple-outbound-dial-peer.html
Thanks!
But why? What are the benefits?
I can see some value in this for loop prevention, so that if a CUBE is configured with a wildcard (e.g +.T) and a call arrives from an ITSP it can be forced to match a PBX-facing outbound dial-peer.
However, ignoring the destination-pattern seems a bit of a stumbling block. Surely one of the reasons to use an SBC is to check the destination-pattern sent by the provider, rather than just offloading that problem to the PBX? I guess you could configure "incoming called e164-pattern-map" on the inbound DP, but most people prefer to do this match on "incoming uri via" as that takes precedence.
The other problem which I foresee is that you might have more than one PBX and want CUBE to route calls to the appropriate far-end based on destination-pattern.
I just found an interesting solution which I was not aware of before I wrote my previous comment. This addresses a situation where:
I hadn't realized the call-block command could work based on DNIS:
! Block at the ITSP facing incoming dial-peer:
dial-peer voice X call-block translation-profile incoming tp-inbound exit voice translation-profile tp-inbound translate called 1 exit voice translation-rule 1
! Search and Replace valid DDI ranges without modification: rule 1 //\(\+XXEnterYourValidDDIRange\)$/ /\1/ ! reject everything else: rule 100 reject /.*/ exit
The above appears to work in CUBE v12, but not in v11 (Denali).
