Wilson Freire
hello I have problems with calls to SKYPE I have the following configuration
CUCM 9.1 >>>>SIP TRUNK >>>>GW 2911 >>>>>>SIP TRUNK >>>>PSTN SP1
                                                            |---->>>>>>>>SIP TRUNK >>>>SKYPE
I have this dial peer
dial-peer voice 4002 voip
description Skype Outgoing
translation-profile outgoing Skype
destination-pattern 18323913448
redirect ip2ip
session protocol sipv2
session target dns:sip.skype.com
session transport udp
voice-class codec 1
voice-class sip profiles 1000
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
sip-ua
credentials username 99051000221230 password 7 111B2332332325282A7E2E027D3A02 realm sip.skype.com
authentication username 99051000221230 password 7 083376792D282B333C5F09227F2213 realm sip.skype.com
registrar 1 dns:sip.skype.com expires 360
registrar 2 ipv4:10.208.26.20 expires 180
18323913448 number is only for testing a direct number
Thanks for your help
vikas-wankhede
Hi Wilson,
 You managed to get this working ?
vikas-wankhede
Hi Wilson,
Wilson Freire
In this momente the integration with skype is working very fine
Do you have any question?
