Jason Burns
    1.  Verify Hostname and Settings
    Certificates are based on names. Make sure the names are correct before starting.
    From SSH CLI
    admin: show web-security
    Subject: CN=CUCM7-PUB.bbbburns.lab, OU=TAC, O=Cisco, L=RTP, ST=North Carolina, C=US
    X509v3 Subject Alternative Name:
                DNS:CUCM7-PUB.bbbburns.lab, DNS:CUCM7-Pub
    Use CLI to change these settings if desired
        In the next example we move to BXB, and set an Alternate name of “ThePub” so we can type that into our browser
    admin: set web-security TAC Cisco BXB Massachusetts US ThePub
    After running "set web-security" Tomcat must be restarted for the new certificate to be used when accessing CCMAdmin and CCMUser.
    admin: utils service restart Cisco Tomcat
    2.  Generate and Download CSR
    OS Admin > Security > Certificate Management > tomcat.pem > Generate CSR
    Download CSR (CUCM7-Pub.csr)
    Note: Prior to CUCM 8.0(3), these Tomcat CSRs were generated with 1024 bit RSA keys. With the resolution of defect
    CSCso62711 Cert Manager should generates Tomcat CSR using RSA 2048 instead of 1024
    CUCM in versions 8.0(3) and later will generate a 2048 bit key / CSR for Tomcat. This defect currently only addresses Tomcat in 8.0(3). Other types of CSRs (like CallManager) will be addressed in future versions. Follow defect CSCtn01236 for 2048 bit updates.
    3.  Submit CSR to CA
    Open the CSR file downloaded from the previous step (CUCM7-Pub.csr in this example) in Notepad and copy the entire contents including the ---BEGIN CERTIFICATE REQUEST--- and ---END CERTIFICATE REQUEST-- lines.
    If your CA is Windows 2k3
    https://<CA Server Name: In my example JASBURNS-AD>/certsrv > Advanced Certificate Request
    Paste the contents into this window to submit the request.
    4.  CA Approves CSR
    This is where the magic happens.
    The CA inspects the CSR and determines if the person submitting the CSR really owns CUCM7-PUB.bbbburns.lab
    With Verisign or GoDaddy this step will require payment, and email or maybe even human verification
    5.  Server Admin Downloads Issued Cert
    With Win2k3 go to CA MMC > Issued Certificates > Copy to file > Base-64 > (CUCM7-Pub.bbbburns.lab.cer)
    6.  Server Admin downloads CA Cert
    The Server Admin must build a complete chain of certs, so needs to download the root CA cert
    https://<CA Server Name: In my example JASBURNS-AD>/certsrv > Download CA Cert > Base-64 > (jasburns-ad_PEM.cer)
    7. Server Admin Uploads Root Certificate(s) as tomcat-trust
    CUCM Server needs to have all certificates in the chain uploaded, starting at the top (root).
    Note that the name of the file uploaded is jasburns-ad_PEM.cer. This is a Base64 encoded PEM file. Once it gets uploaded to CUCM though it will show up with filename JASBURNS-AD.pem. CUCM changes the name of the file to <SUBJECT CN>.pem.
    7b.  Uploading an intermediate certificate
    This step is only necessary if the Certficate Authority (CA) has provided a signed certificate with multiple certificates in the certificate chain as shown.
    After uploading the root certificate in Step 7, export the intermedia certificate and upload it as a Tomcat-trust also while specifying the filename (minus the extension) of the root certificate in the "Root Certificate" field.
    If there are more intermediate certificates in the chain, each one will need to be uploaded in order until finally uploading the signed certificate as shown in Step 8.
    The purpose here is to build a chain of certificates. We upload the root certificate and leave the root cert field blank. When we upload the 1st intermediate certificate we put the file name of the root certificate in the root cert field. If there is 2nd intermediate, we put the name of the 1st intermediate in the root cert field. This builds the chain of trust that can be followed from the identity certificate to the root certificate.
    8.  Server Admin Uploads Identity Certificate as tomcat
    This is the identity certificate issued by the CA.
    Complete the cert chain by specifying .pem root cert. Note that the name below is JASBURNS-AD.pem. That's because I went to the OS Admin Certificate page to get the name of the newly uploaded tomcat-trust certificate from the last step. This is VERY important.
    The root certificate you specify here could be the name of the root cert, or the name of some intermediate cert. The purpose is to find the certificate that signed the identity certificate, and use that certificate file name in this root cert field.
    9.  Restart Tomcat
    This one is pretty simple. Just restart Tomcat from the SSH CLI
    When Tomcat comes back up you can access the CCMAdmin or CCMUser GUI to verify your newly added certificates in use.
    GalaRetail
    Community Member
    Hi Great article thanks.
    Quick question/problem if I can. Generated CSR and completed certificate request without issue from our internal CA, we already had the root/Chain on there so no problems there, after uploading the cert to CUCM 10.5 as tomcat trust type it displays and looks valid with a date in the future. However there is a self signed certificate "generated by system" with a expiry date of several years in the future which after restarting the tomcat service assigned itself as the web cert, is there a way to either remove this cert or assign the CA cert to the tomcat service? As a side note after restarting the tomcat service the CA cert is removed from the list as if the CUCM believes its not needed, I can simply re-add it again without a problem, thanks for any help.
    Phillip Ratliff
    After generating a CSR for tomcat and getting it signed by your CA the resulting certificate should be uploaded as a tomcat certificate, not tomcat-trust. This is how you replace the self-signed certificate generated by the system with the one that corresponds to the CSR you generated.
    The system will validate the certificate you are uploading against the last CSR that was generated so you cannot inadvertently replace the service certificate.
    GalaRetail
    Community Member
    Thanks for the reply. upon attempting to upload a tomcat only cert I receive the attached error, "java.security.cert.certpathbuilderexception: certificate verify failed!" any suggestions to get around this?
    pankajk5
    GalaRetail,this issue might come if you have more than one intermediate CA server.Make sure that you have single Intermidiate CA server while generating certificate.
    jwilson
    Hello.  I realize this article goes back many years but does anyone know with UCM 12.5 or newer if this process can be automated some?  I mean is there an API or other way to generate the CSR or does that have to be done via the WebUI?  Our 3rd Party CA forces us to renew our Tomcat certs once a year.  Looking for a faster easier more routine way.  Thank you.
