cdnadmin
Community Member
This document was generated from CDN thread
Created by: Ryan Hilfers on 15-05-2012 01:23:05 PM
Wondering if anyone would be willing to share an example of a custom logger they've implemented. I have a few ideas I would like to explore with using a custom logger instance and having a basic custom logger java class to work off of would really speed the learning curve, will happily share my custom logger back with the community.
-Ryan
Quigath
This is an old thread but were you able to get your custom logger working? Have code to share? Thanks!
