cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Zelino Rocha on 25-02-2013 09:06:48 AM
I have to call a webservice which has WS-Security authentication. Since the Webservice element is only prepared to deal with http authentication, I'm trying to find out the best solution to work around it.
Any sugestions?
Thanks!
Subject: RE: New Message from Zelino Rocha in Customer Voice Portal (CVP) - CVP - Al
Replied by: GEOFFREY THOMPSON on 25-02-2013 09:58:16 AM
I build custom classes to call Web Services. The basis is Apache Axis.
Geoff
Replied by: Hemal Mehta on 25-02-2013 10:30:54 AM
Build your own web services code. You can either do it in Studio and import a web services plugin. Alternatively you can easily do it using eclipse IDE EE version. It uses Apache Axis 2.   You can generate the code manually also using command line.
Hemal
From: Cisco Developer Community Forums [mailto:cdicuser@developer.cisco.com]
Sent: Monday, February 25, 2013 9:07 AM
To: cdicuser@developer.cisco.com
Subject: New Message from Zelino Rocha in Customer Voice Portal (CVP) - CVP - All Versions: CVP - Webservice with WS-authentication
Zelino Rocha has created a new message in the forum "CVP - All Versions": --------------------------------------------------------------
Any sugestions?
Thanks!
To respond to this post, please click the following link: http://developer.cisco.com/web/cvp/community/-/message_boards/view_message/12351399 or simply reply to this email.
