08-06-2023 02:49 PM - edited 08-07-2023 10:51 AM
Dial Plan Design With a distributed Cisco UCM Cluster and Cisco CMS Cluster in Multisite Architecture.
The deployment consists of one Cisco UCM Cluster and one Cisco CMS Cluster distributed accross three sites, US, UK and GE. In this type of deployment, there are some recommendations that should be taken into considerations
The first recommendation is to reduces the number of distribution links required to connect the participants in the conference, and therefore reduces the load across the CMS node and distributed calls accross the WAN. To achieve this requirement, we use the CallBridge Group feature. We create Three CallBridge Groups for each site, and we associate the local to each CallBridge Group.
The second recommendation is to optimize the outgoing calls from the Cisco UCM Cluster.
A SIP Trunk must be configured to each CallBridge.
Three Route Groups for each site must be created to group the SIP Trunk to the remote CallBridges located in each site. For example the Route Group RG-UK will group the CallBridges of the Site United Kingdom UK (UK-CMS1 and UK-CMS2).
Three Device Pools and three UCM Groups must be created for each site.
Each UCM Group must be associated to the corresponding Device Pool, for example, the UCM Group RG-UK will be associated to the Device Pool DP-UK.
Each endpoint will use the Device Pool to register to the local Call Controls.
All CallBridges share the same space and a single Route Pattern must be created with a single Route List. The Calls received by the Call Control must be routed to the local CallBridges. To achieve this, we need to use the Local Route Group with a single Route Pattern and Route List. The decision to route the calls to the local CallBridges is done through the Device Pool where the Local Route Group for each site is associated.
For the CallBridge Group to work, There are two requirements:
The first requirement: We need to enable the "Accept Replaces Header" on all SIP Trunk so that the call control is able to move SIP calls between Call Bridge Groups as instructed by the CallBridges when sending the SIP INVITE with Replaces Header.
The second requirement: we need to assign the appropriate Rerouting CSS on all SIP Trunk, this Rerouting CSS must include the Line Partition of the endpoint so that the Call Control is able to send a SIP UPDATE to the endpoint when moving the call to another CallBridge hosting the meeting.
Finally to optimize the outgoing calls from the Call Controls's perspective, we need to enable the "Run On All Active Unified CM Nodes" option on the Route List and the SIP Trunks, this option ensures that the Call Control where the endpoint is registered to is always used to route the egress calls.
In this scenario, there are two separate CUCM clusters.
A Cluster of two Cisco Meeting Servers are distributed accross sites. HQ-CMS is deployed in HQ-Site while BB-CMS is deployed in BB-Site.
Both CMS are clustered and share the same space with the User Part URI 882222.
To optimise intersite bandwidth usage, the local CUCM should send calls to join meeting from local users to local Cisco Meeting Server, if the local CMS is not available, the remote Cisco CMS can be used as a backup.
To optimize load balancing with failover, if the local CMS is not available, a prefix « 8 » must be added when a user dial 882222 by the local CUCM and the called number 8-882222 will be presented to the remote CUCM.
The remote CUCM must have a route pattern 8.88XXXX to route the call to remote CMS. The prefix « «8 » must be stripped before sending the call so that the call number 882222 will match the User Part URI of the space World Cup Espana 1982.
SIP Trunks are configured as follow:
To design our dial plan.
On each CUCM, we need two Route Groups.
On HQ-CUCM.
On BB-CUCM.
Now we need two Route Lists on each CUCM.
On HQ-CUCM.
On BB-CUCM.
Finally, we configure two Route Patterns on each CUCM.
On HQ-CUCM.
On BB-CUCM.
To connect successfully jabber client to the remote CMS in the event that the local CMS is not available we need to perform two digits manipulation of the dialed number 882222.
The first digits manipulation is to add prefix « 8 » to the called number 882222 when the call from Zico user located at the HQ-Site is sent to the remote CMS BB-CMS through the SIP Trunk to BB-CUCM. This transformation is done at the Route Group RG-BB-CMS-RMOTE in the Route List Details RL-HQ-CMS-Failover.
For Zoff user located at the BB-Site, the same logic is applied. When the call is sent to the remote CMS HQ-CMS through the SIP Trunk to HQ-CUCM. This transformation is done at the Route Group RG-HQ-CMS-RMOTE in the Route List Details RL-BB-CMS-Failover.
The second digits manipulation is to strip the prefix « 8 » when the call arrives at the remote CUCM.
For Zico user, once the call with called number 8-882222 arrives at BB-CUCM, the route pattern 8.882XXX wil route the call to BB-CMS, but before sending out the call, we need to strip the prefix « 8 » at the Route Pattern level 8.882XXX using the Discard Digits « PreDot ».
For Zoff user, the same logic is applied, once the call with called number 8-882222 arrives at HQ-CUCM, the route pattern 8.882XXX wil route the call to HQ-CMS, but before sending out the call, we need to strip the prefix « 8 » at the Route Pattern level 8.882XXX using the Discard Digits « PreDot ».
The Dial Plan should configured as follow :
On HQ-CUCM
On BB-CUCM
Three separate Clusters CUCM are deployed with Multisite Architecture in the US site, GE site and AU site.
A single Cluster Cisco Meeting Server is deployed and distributed accross the WAN. Each Site contains two Cisco Meetine Server nodes running the callbridge services.
The Cluster CUCM in each site is trunked to the local callbridges.
Each cluster CUCM IS trunked to the SME as leaf nodes.
Standard Local Route Group will be used to reduce the number of Route Pattern, Route List, CSS and Partitions. The SIP Trunk selection for outgoing calls is based on the Route Group at the device pool level.
In each site, the call control contains two Route Groups, the first Route Group contains the SIP Trunks to the local callbridges and the second Route Group contains the SIP Trunk to SME.
On US-CUCM :
On GE-CUCM :
On AU-CUCM :
On each CUCM cluster (US, GE, AU and SME), a single route pattern pointing to a Route List containing two Local Route Groups.
In this deployment, the design of Device Pool is very important to achieve the goal of Load Balancing and Failover.
Device Pools in this deployment have three goals.
The first goal. For each site, routing calls to the local callbridges, if the local resources are not available, call must be sent to the remote callbridges.
In this case, a device pool for each site’s phones must contains two Local Route Groups :
Local Route Group LRG-LOCAL populated with the Route Group (RG-US, RG-GE and RG-AU) that contains the corresponding local callbridges.
Local Route Group LRG-REMOTE populated with the Route Group RG-SME that contains the SIP Trunk to SME.
You must create a device pool for each site (DP-US, DP-GE and DP-AU) and assign it to the phone.
On US-CUCM :
On GE-CUCM :
On AU-CUCM :
The second goal is for processing incoming calls from each site to SME. The SME must be able to process inbound calls when a specific Call Control wants to failover to another site in case of unavailability of the local resources.
For example, for users on US Site, if the local callbridges US-CMS1 and US-CMS2 are not available, the SME must process the incoming calls from US-CUCM in order to connect the users at the US Site to the remote callbridges (either to GE callbridges or AU callbridges) so that they will be used as a backup.
The same logic is valid to incoming calls from GE-CUCM and AU-CUCM.
To achieve this second goal, three device pools should be created on SME, let’s say DP-US-SITE, DP-GE-SITE and DP-AU-SITE.
Each device pool should have the following settings for the Local Route Groups LRG-LOCAL and LRG-REMOTE :
For US Site, SME should be configured with :
1-Route Group RG-US-SITE that contains the SIP Trunks to GE-CUCM and AU-CUCM.
2-Device Pool DP-US-SITE with :
For GE Site, SME should be configured with :
1-Route Group RG-GE-SITE that contains the SIP Trunks to US-CUCM and AU-CUCM.
2-Device Pool DP-GE-SITE with :
For AU Site, SME should be configured with :
1-Route Group RG-AU-SITE that contains the SIP Trunks to US-CUCM and GE-CUCM.
2-Device Pool DP-AU-SITE with :
To make the failover process fine, SME must be able to process incoming calls from US GE and AU sites so that US Calls will be sent to GE or AU callbridges (GE calls to US or AU callbridges, AU calls to US or GE callbridges), we need to associate the Device Pool to the appropriate SIP Trunk.
The implementation should be :
The third goal is to process the incoming calls at the remote sites when SME sends out the inbound calls after failover.
On each call control (US-CUCM, GE-CUCM and AU-CUCM), we need a device pool for calls coming from SME.
Each remote site must select the local callbridge to connect the call. In order to achieve this goal. The Local Route Group settings on each device pool must be set as follow :
On US-CUCM :
1-Route Group RG-US that contains the SIP Trunks to local callbridges US-CMS1, US-CMS2.
2-Device Pool DP-SME with :
On GE-CUCM :
1-Route Group RG-GE that contains the SIP Trunks to local callbridges GE-CMS1, GE-CMS2.
On AU-CUCM :
1-Route Group RG-AU that contains the SIP Trunks to local callbridges AU-CMS1, AU-CMS2.
Then assign the device pool to the SIP Trunk that receives the incoming calls from SME as follow :
On US-CUCM :
SIP Trunk to SME must be in the device pool DP-SME.
On GE-CUCM :
On AU-CUCM :
Below summary of the design.
Chart Call Flow
