Problem Description
DSP resetting and Call Drops after the DSP Alarm received on 2921 voice gateway with PSTN E1/T1 Interface card and PVDM Modules .
This document provides the information about the DSP Alarm and the Work around for the problem.
DSP Alarm
%DSPRM-3-DSPALARM: Received alarm indication from dsp (0/1). Resetting the DSP.
%DSPRM-3-DSPALARMINFO: 002A 0000 0080 0000 0008 0008 5761 7463 6844 6F67 2054 696D 656F 7574 2C20 5043 3D30 3030 6539 3663 3400 4E5F 0000 0000 0000
%DSPRM-3-DSPALARMINFO: WatchDog Timeout, PC=000e96c4
DSP trace buffer dump for DSP 0/1
DSP version: 26.3.8
Trace buffer size: 1392 bytes
===== Begining of DSP tracebuffer dump=====
DSPTB0:00058DD0 00057945 00057944 00057ADB 00057AC6 0014542D 00145428
Hardware : Cisco 2921 router running C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M4.
The PSTN interface card is VWIC2-2MFT-T1/E1 and PVDM3 DSP DIMM with 32 channels on slot 0
Bug Details
CSCtj71414 Bug Details
dsp crash in ecan when max tail delay configue in 32ms |
Symptom: dsp crash
Conditions: when max tali lehgth of ecan is configure smaller than 80 ms.
Workaround: use default value as 128ms. |
Work around
Use default value as 128ms
Change all the Voice-ports and have echo-cancel coverage configured to 128 (default value)
Configuration :
voice-port 0/2/0:15
echo-cancel coverage 128
This document was generated from the following thread: DSP resetting after alarms - Calls Dropped
