cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mark Applebee on 23-08-2013 06:58:21 AM
 am trying to creat my first dynamic audio element and getting the following error messge:
The error was: The dynamic configuration cannot return a null element configuration.
The code is below. Please let me know what I am missing.
public VoiceElementConfig getConfig(String name,  ElementAPI elementAPI,VoiceElementConfig defaults) throws AudiumException
   // PUT YOUR CODE HERE.
  try
 AudioGroup initAudioGroup = defaults.new AudioGroup("initial_audio_group", true );
defaults.setAudioGroup(initAudioGroup);
StaticAudio  mailAudio1 = defaults.new StaticAudio("Test", "200002.wav");
mailAudio1.setUseDefaultAudioPath(true);
initAudioGroup.addAudioItem(mailAudio1);
  }catch(Exception e){
    elementAPI.addToLog("Exception Occurred",e.getMessage());
return defaults;
Subject: RE: Dynamic Voice Element
Replied by: Janine Graves on 23-08-2013 09:55:06 AM
Your dynamic configuration should check whether the parameter it's receiving (named 'defaults') is null. If it is null, then you need to reinstantiate it before adding data to it.
try
          if (defaults ==null) {
                 defaults = new VoiceElementConfig();
          etc, etc, etc.
