tom_chan
Community Member
We have a VWIC2-2MFT-T1/E1 on 3845 and is trying to connect to an IPC. Suspecting it might be framing, line code etc mismatching.
Thanks for the advice if anyone experience the similar issue.
Also what is the debug syntax command to look into controller E1?
VG#show run
controller E1 0/0/0
framing NO-CRC4
clock source internal
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Receiver has remote alarm.
  alarm-trigger is not set
  Version info Firmware: 20071011, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (58 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 58 Unavail Secs
mightyking
Level 11
Level 11
Try framing CRC4. If it still shows down put a loopback on the router and contact the provider. It could be a circut or a switch port issue.
MK
tom_chan
Community Member
Thanks for the comment.
Since it is a VWIC2-2MFT-T1/E1, do we need any command to specifically tell the card is an E1 card?
mightyking
Level 11
Level 11
Issue the "card type e1 slot [bay]" command in global mode.
MK
