sacartwr
Great audio requires a consistent end-to-end solution that can capture, process, and reproduce the sounds of a meeting. Cisco Webex Room and Webex Room Kit Series are now delivered with new microphones and multi-head cables.
New internal and external microphones
Our new microphones, both internal and external are designed to capture the full sound spectrum in a room and to minimize the signal-to-noise ratio as well as known artifacts such as shadowing, reverb, comb filtering etc.
For additional spare parts, look up CS-TABLE-MIC-J= (jack) and CS-TABLE-MIC-E= (euroblock). If you already have the original Table Microphone and you want to order more of the same, you can order the spare original Table Microphone CTS-MIC-TABL20= and CTS-MIC-TABL60=
New multi-head cables
The new multi-head cables provide flexibility and security in screen-sharing scenarios. One single cable with an integrated set of connectors reduces points of failures.
Resources
