cdnadmin
Community Member
This document was generated from CDN thread
Created by: Beena Jacob on 15-01-2013 02:10:54 PM
I'm getting an error while trying to play a message using admin credentials. The admin used for authentication has mailbox delegate role. I am able to connect to the specified extension successfully but not able to play the message on the specified extension.  Below is the request sent to server and the error received. if I use the user credentials and send the request mentioned below it works fine but I need this to work with admin user that has Mailbox delegate role. REQUEST   URI:https://10.3.105.181:8443/vmrest/calls/8   Method: POST  Body:{"op":"PLAY","resourceType":"MESSAGE","resourceId":"0:689542d2-4218-4cf3-9c21-676c0d7a58e8", "speed":"100","volume":"100","startPosition":"0","lastResult":"0"}     RESPONSE   Status returned 400:Bad_Request Raw Response Text: {"errors":{"code":"INVALID_PARAMETER","message":"mailbox can't be created for user: id=c253e9d2-2502-4c0d-879f-9ab5f2067fb1, message=null "}}
Subject: RE: Error with message playback using admin credentails
Replied by: Utkarsh Katiyar on 15-01-2013 09:53:05 PM
With Admin credentials you need to pass the userobjectid as the query parameter, it will be the user who is calling.
With Admin credentials:
/vmrest/calls/8?userobjectid=<objectid>
With user credentials:
/vmrest/calls/8
If the userobjectid is not passed, the logged in user is treated as the mailbox user but an admin user is not someone who owns a mailbox. That is why you are getting this error.
-Utkarsh
Replied by: Beena Jacob on 16-01-2013 10:50:15 AM
Thanks Utkarsh! That worked. It'll be very helpful to others if this info is updated in your CUTI docs. We knew that it needs userobjectid but didn't know where to pass this info.
Replied by: Utkarsh Katiyar on 16-01-2013 12:04:21 PM
Sure, we will update the docs.
