Bryan Deaver
# app_hookflash.tcl
# written by Bryan Deaver based on the default session application.
# This is an example of converting a * dtmf event into hookflash out the fxo port.
# This is written as is with no claims of support.  It has been shown to work
# to convert a * h245-alhpanumeric event from callmanager while running on a c2800
# gateway running 12.4(20)T.  There are other modifications that would be done
# for example look at * 8 before forwarding the other digits.
# Or converting an A/B/C/D dtmf event into hookflash to interwork with
# other applications.  If you find a useful modification, please do drop me a note
# at bdeaver@cisco.com
# This is based upon the default session application as seen with
# "show call application voice session" on the router.  This provides an
# easy start by which to modify scripts to fit your needs.
# The modification of the session script was to add the act_ProcessDTMF function,
# add a section to look for digits coming in from the outgoing call leg
# as well as add an entry to the fsm table.
#   Example Script
proc act_Setup { } {
    global dest
    global beep
    set beep 0
    if { [infotag get leg_isdid] } {
        set dest [infotag get leg_dnis]
        leg proceeding leg_incoming
        leg setup $dest callInfo leg_incoming
        fsm setstate PLACECALL
    } else {
        leg setupack leg_incoming
        playtone leg_incoming tn_dial
        set param(dialPlan) true
        leg collectdigits leg_incoming param
proc act_GotDest { } {
    global dest
    set status [infotag get evt_status]
    if {  $status == "cd_004" } {
        set dest [infotag get evt_dcdigits]
    } else {
        puts "\nCall [infotag get con_all] got event $status collecting destination"
        # use invalid-number cause code
        leg disconnect leg_incoming -c28
        call close
# here is the process that intercepts the '*' and sends out a hookflash
proc act_ProcessDTMF { } {
# get the dtmf and duration
     set dtmf_value [infotag get evt_digit]
     set dtmf_duration [infotag get evt_digit_duration]
     if {$dtmf_value == "A"} {
          leg sendhookflash leg_incoming
     } else {
# ok, not a * so playout the dtmf event with the same duration
          leg senddigit leg_incoming $dtmf_value -t $dtmf_duration
proc act_CallSetupDone { } {
    global beep
    if { $status == "ls_000"} {
        set  creditTimeLeft [infotag get leg_settlement_time leg_all]
        if { ($creditTimeLeft == "unlimited") ||
             ($creditTimeLeft == "uninitialized") } {
            puts "\n Unlimited Time"
        } else {
            # start the timer for ...
            if { $creditTimeLeft < 10 } {
                set beep 1
                set delay $creditTimeLeft
            } else {
                set delay [expr $creditTimeLeft - 10]
            timer start leg_timer $delay leg_incoming
# setup the outgoing leg to monitor for digits
          set param(consumeDigit) true
          set param(enableReporting) true
        leg collectdigits leg_outgoing param
    } else {
        puts "Call [infotag get con_all] got event $status collecting destination"
        call close
proc act_Timer { } {
    global beep
    global incoming
    global outgoing
    set incoming [infotag get leg_incoming]
    set outgoing [infotag get leg_outgoing]
    if { $beep == 0 } {
        #insert a beep ...to the caller
        connection destroy con_all
        set beep 1
    } else {
        fsm setstate LASTWARN
proc act_LastWarn { } {
    media play leg_incoming flash:out_of_time.au }
proc act_Destroy { } {
    media play leg_incoming flash:beep.au }
proc act_Beeped { } {
    global incoming
    global outgoing
    connection create $incoming $outgoing }
proc act_ConnectedAgain { } {
    timer start leg_timer 10 leg_incoming }
proc act_Ignore { } {
# Dummy
    puts "Event Capture"
proc act_Cleanup { } {
    call close
#   State Machine
  set fsm(any_state,ev_disconnected)  "act_Cleanup              same_state"
  set fsm(any_state,ev_digit_end)     "act_ProcessDTMF     same_state"
  set fsm(CALL_INIT,ev_setup_indication) "act_Setup            GETDEST"
  set fsm(GETDEST,ev_collectdigits_done)  "act_GotDest          PLACECALL"
  set fsm(PLACECALL,ev_setup_done)    "act_CallSetupDone    CALLACTIVE"
  set fsm(CALLACTIVE,ev_leg_timer)    "act_Timer            INSERTBEEP"
  set fsm(INSERTBEEP,ev_destroy_done) "act_Destroy          same_state"
  set fsm(INSERTBEEP,ev_media_done)   "act_Beeped           same_state"
  set fsm(INSERTBEEP,ev_create_done)    "act_ConnectedAgain   CALLACTIVE"
  set fsm(LASTWARN,ev_destroy_done)     "act_LastWarn        CALLDISCONNECT"
  set fsm(CALLACTIVE,ev_disconnected)   "act_Cleanup         CALLDISCONNECT"
  set fsm(CALLDISCONNECT,ev_disconnected)   "act_Cleanup         same_state"
  set fsm(CALLDISCONNECT,ev_media_done)     "act_Cleanup         same_state"
  set fsm(CALLDISCONNECT,ev_disconnect_done) "act_Cleanup         same_state"
  set fsm(CALLDISCONNECT,ev_leg_timer)      "act_Cleanup         same_state"
  fsm define fsm CALL_INIT
Hey Bryan,
Do you have any examples of how to use this is in the router's config?
