Introduction
Please provide brief introduction about the topic and mention this document answers frequently asked question about the Cisco Product / Technology.
Q1. What does the Answer File include?
A. The answer file is the same xml config file generated by the AFG tool. It contains the config info needed for the install process.
Q2. Is there a specific OVA for PCD? Does that include the bootable iso for PCD as well?
A. Yes. The PCD OVA contains the complete PCD image.
Q3. Do I have to delete the ITL files from the phones if I am migrating to CUCM 10.x via PCD?
A. No. PCD will take a copy of the existing cluster SAST private & public key & restore in CUCM 10.x. New certificates in CUCM 10.x will be created using these keys. Therefore, the phone will be able to register directly to CUCM 10.x without having to delete ITL files.
Q4. Does PCD support BE6K migration as well?
A. Not at this time
Related Information
  • Link 1
  • Link 2
Note:
  • Provide the relevant Document/Tool link for reference. Say for example, if you have taken any Product Installation/Configuration Guide as reference for creating this document then you can provide the same link in this section.
  • When you are referring any Tool/link which requires CCO login then Pl mention the same.
