A “Fresh Install with Data Export” is a native method used to migrate UC application clusters to a new version while preserving the existing configuration data.
I personally prefer using Cisco’s PCD for migrations. However, since PCD is in survival mode, Cisco recommends using the native option, which is the “Fresh Install with Data Export.”
Cisco is in the process of bringing all the capabilities of PCD natively to CUCM.
In this blog, I explain how to export data from an old cluster to an SFTP server for use in a Fresh Install. You can also perform the fresh install using a touchless installation with an AFG file. To learn more about Touchless VM installation, please refer to my previous blog.Touchless VM installation .
This process involves exporting data from the current UC cluster and importing it into a newly installed cluster. Let’s split this into the following 3 tasks:
Task 1: Identify the Versions
You need to determine if the version you are moving to supports a fresh install with data export. If the utils system upgrade dataexport initiate command is not available on the source cluster, you need to install the COP files mentioned below.
Supported Versions for Fresh Install with Data Export:
  • CUCM & IMP: Supported on versions 12.5SU5/14+ and source releases 10.5, 11.5, 12.5, 14.
  • CUC: Supported on version 14SU1 and above. Migration is possible from 11.5.x, 12.0.x.
COP Files for Versions Without utils system upgrade dataexport initiate:
  • CUCM/IMP: ciscocm.DataExport_v4.0.cop.sha512 (applicable on 10.5, 11.x, 12.x up to 12.5 SU4).
  • CUC: ciscocm.cuc_DataExport_v1.1.k4.cop.sha512 (applicable on 11.5.x, 12.0.x to pre-12.5SU5, and 14FCS). From 12.5SU5, the command is natively available on CUC.
Note: Make sure to read the release notes of the data export COP before installing it.
Since this is a release key signed COP, the installation of ciscocm.enable-sha512sum-v1.0.cop.sgn is required before installing the data export COP file ciscocm.cuc_DataExport_v1.1.k4.cop.sha512 on the following Cisco Unity Connection versions:
  • 11.0.x to pre-11.5SU10
  • 12.0.x to pre-12.5SU4
I have not included the details on how to install the COP file on UC applications here. However, I will create a separate blog on installing the COP file and mention the link here later.
Task 2: Export Data from the Source Cluster
You need an SFTP server to transfer the exported data. Before exporting the data, ensure you have an accessible SFTP server that the UC application can reach. For this blog, I have used SolarWinds SFTP applications.
First, you need to export the data from the Publisher node, followed by the Subscriber nodes, including IMP in the cluster.
  1. Publisher:
    • Log in to the CUCM Publisher’s command line interface.
    • Run the command utils system upgrade dataexport initiate.
  • Provide the SFTP server details and monitor the export progress using utils system upgrade dataexport status.
The status will show “completed” with a message “migration export completed successfully.”
If the migration fails for any reason, you will see a “terminated” message along with the reason for the termination as mentioned in the images below.
  • The data export command will create a folder inside the SFTP directory you provide, named cluster-<IP ADDRESS OF PUBLISHER>. Inside this folder, you will find a Clusterinfo.xml file and tar files for each node in the cluster, as shown in the images below.
  1. Subscriber:
    • Repeat the same steps for the Subscriber node.
Task 3: Fresh install the Clsuter with importing the data.
  1. Shutdown the Source Cluster
This is rew=quired when yyou are migrating to the same IP. If you are migrating to different IP this shutdown is not required.
  • Execute utils system shutdown on both the Publisher and Subscriber to safely power down the source cluster.
  1. Install the New Publisher
    • Set up a virtual machine for the new Publisher using the appropriate OVA template.
    • Mount the CUCM bootable image and start the installation.
  • Choose the import option in the Platform Installation Wizard
  •  The Component installation will proceed
  • You will see the “Import Upgrade Configuration Information” page.
  • Before proceeding with the data import, you need to configure the network settings.
  • Provide the SFTP server details to import the exported data.
  • Complete the certificate and NTP configurations, and the installation will finish after some time.
  1. Install the New Subscriber
    • Follow similar steps as the Publisher installation.
    • Ensure the Subscriber is configured to connect to the new Publisher.
    • You will be prompted to specify whether this is the first node or not, for subscriber choose yes
  • You will be asked to enter the hostname and IP address of the Publisher node.
Note: The security password will be auto-populated, so you do not need to provide it again.
  • The installation will proceed after validating connectivity to the Publisher.
  1. Verification
    • After installation, verify the setup by running commands like show myself, show version active, and utils dbreplication runtimestate.
jaheshkhan
Level 10
Level 10
Can we migrate from Cisco Unity Connection 10.5 to Unity Connection 15 using the data export/import method?
Is an intermediate upgrade path required—such as upgrading from 10.5 to 11.5, then to 12.5, and finally to 15—even when using the data export/import method?
is data export/import method in cuc only support from 10.5?
CUC 10.5 --> CUC 11.5 --> cuc 12.5 --> CUC 15.x
jaheshkhan
Level 10
Level 10
Can we migrate Cisco Unity Connection 10.5 to Unity Connection 15 using the data export/import method?
Do we need to upgrade first to version 11.5 or 12.5?
Alternatively, is it required to perform an in-place upgrade from 10.5.2 to 11.5, then an in-place upgrade to 12.5, install the required COP files, perform a data export, and finally import the data into a new Unity Connection 15 virtual machine?
cuc 10.5-inplace upgrade->11.5 -inplace upgrade->12.5-Data Export/import->15.0
but this required esxi upgrade in between also right?
Or can we install the required COP files on Unity Connection 11.5 after inplace upgrade, perform the data export, and then use the data import installation method directly on a new Unity Connection 15 virtual machine?
cuc 10.5-inplace upgrade->11.5 --Data Export/import->15.0
