05-09-2016 05:56 AM - edited 03-12-2019 10:22 AM
Please rate helpful content (i.e. videos, documents, comments) so quality content shows at the top of people's search results. Also, please select the correct answer(s) if any comment(s) answers your question otherwise the question remains on the support forums as unanswered.
I am planning on putting together a small video series about reading CallManager service traces and I am in the process of looking up good links to provide for signaling examples. I couldn't find any quality ones online so I went to some of my notes to pull out diagrams and put them here for the masses.
Note: This is not meant to be an in depth document. The point of this document is
to provide some quality, high level information about H.323.
EP = End Point
TCS = Terminal Capabilities Set
MSD = Master Slave Determination
OLC = Open Logical Channel
In this example EP1 is the originating side for the call; therefore, EP1 sends the setup message to EP2. The yellow arrows indicate H.225 while the black arrows indicate H.245.
Here are some notes about the signaling:
Before exchanging the TCS's there needs to be an H.245 connection opened. This is
accomplished by sending the H.245 address (IP address) and the port to connect to.
Once both sides know the H.245 address and port they can setup the connection and
exchange what capabilities they support (i.e. codec, packetization rate, etc...),
then MSD determination so when there are conflicts the Master can resolve them if
possible, then the OLC messages will be sent and this will prompt an OLC
Acknowledgement (OLCAck) which will carry the IP address and port for where to
terminate media (where to send the RTP packets). After the OLCAcks we see RTP
is established.
Note: The H.245 address is sent in the connect message for the example above;
however, it is possible to send it in an earlier message such as the call
proceeding, facility, or a progress message. If the far end device is a Cisco voice gateway the default is to send the H.245 address in the call proceeding message.
There are other setup types such as fast connect (aka fast start) and cut-through
(cut-through is similar to early media with SIP). Fast Connect and Early Media are very similar; however, they are considered to be different.
It will look almost the same in CUCM traces.
https://supportforums.cisco.com/document/62906/how-properly-and-safely-collect-debugs-ios-router
Call flow: PSTN --> Circuit on Cisco router --H.323--> CUCM --SCCP--> Phone
NOTE: For the example below the originating side sent the setup with fast connect;
however the terminating side didn't do fast connect so we see the signaling go on
as slow start.
##### 08:10:17.066 || OUTGOING || h323-message-body setup
May 10 08:10:17.066 EDT: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body setup :
protocolIdentifier { 0 0 8 2250 0 4 }
sourceAddress
h323-ID : {"RTR1"}
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
activeMC FALSE
conferenceID 'FE05EF3115DE11E68005001B53B46B00'H
conferenceGoal create : NULL
callType pointToPoint : NULL
sourceCallSignalAddress ipAddress :
ip '0E3026FC'H
port 62896
callIdentifier
guid 'FE07281A15DE11E6A5AFEC1BFB413625'H
fastStart
'0000000D4001800B050001000E3026FC455180'H,
'400000060401004D40018012150001000E3026FC...'H
mediaWaitForConnect FALSE
canOverlapSend FALSE
multipleCalls TRUE
maintainConnection TRUE
symmetricOperationRequired NULL
h245Tunneling TRUE
nonStandardControl
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data 'E0010300010480DA04038090A21803A983811E02...'H
tunnelledSignallingMessage
tunnelledProtocolID
id tunnelledProtocolAlternateID :
protocolType "gtd"
messageContent
'49414D2C0D0A50524E2C6973646E2A2C2C415454...'H
tunnellingRequired NULL
##### 08:10:17.086 || INCOMING || h323-message-body callProceeding
May 10 08:10:17.086 EDT: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body callProceeding :
protocolIdentifier { 0 0 8 2250 0 5 }
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
productId '436973636F43616C6C4D616E61676572'H
versionId '31'H
terminal
mc FALSE
undefinedNode FALSE
callIdentifier
multipleCalls FALSE
maintainConnection FALSE
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '820400000400010300'H
##### 08:10:17.102 || INCOMING || h323-message-body alerting
May 10 08:10:17.102 EDT: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body alerting :
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
versionId '31'H
terminal
mc FALSE
undefinedNode FALSE
callIdentifier
multipleCalls FALSE
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
##### 08:10:17.114 || INCOMING || h323-message-body notify
May 10 08:10:17.114 EDT: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body notify :
callIdentifier
h245Tunneling FALSE
##### 08:10:19.914 || INCOMING || h323-message-body connect || h245Address ipAddress
May 10 08:10:19.914 EDT: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body connect :
h245Address ipAddress :
ip '0E302606'H
port 37766
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
versionId '31'H
terminal
mc FALSE
undefinedNode FALSE
callIdentifier
multipleCalls FALSE
h245Tunneling FALSE
nonStandardControl
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '8204020004000103000100'H
##### 08:10:19.934 || INCOMING || h323-message-body notify
May 10 08:10:19.934 EDT: H225.0 INCOMING PDU ::=
h323-uu-pdu
callIdentifier
h245Tunneling FALSE
##### 08:10:19.946 || OUTGOING || request : terminalCapabilitySet
May 10 08:10:19.946 EDT: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 7 }
multiplexCapability h2250Capability :
maximumAudioDelayJitter 20
receiveMultipointCapability
multicastCapability FALSE
multiUniCastConference FALSE
mediaDistributionCapability
centralizedControl FALSE
distributedControl FALSE
centralizedAudio FALSE
distributedAudio FALSE
centralizedVideo FALSE
distributedVideo FALSE
transmitMultipointCapability
receiveAndTransmitMultipointCapability
mcCapability
centralizedConferenceMC FALSE
decentralizedConferenceMC FALSE
rtcpVideoControlCapability FALSE
mediaPacketizationCapability
h261aVideoPacketization FALSE
logicalChannelSwitchingCapability FALSE
t120DynamicPortCapability FALSE
capabilityTable
capabilityTableEntryNumber 6
capability receiveAudioCapability : g729AnnexA : 2
capabilityTableEntryNumber 5
capability receiveAudioCapability : g729 : 2
capabilityDescriptors
capabilityDescriptorNumber 1
simultaneousCapabilities
5,
6
##### 08:10:19.954 || OUTGOING || request : masterSlaveDetermination
May 10 08:10:19.954 EDT: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
terminalType 60
statusDeterminationNumber 3236
##### 08:10:19.962 || INCOMING || request : terminalCapabilitySet
May 10 08:10:19.962 EDT: H245 MSC INCOMING PDU ::=
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 10 }
maximumAudioDelayJitter 60
centralizedVideo TRUE
mcCapability
capabilityTable
capabilityTableEntryNumber 1
capability genericControlCapability :
capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
capabilityTableEntryNumber 2
capability receiveAudioCapability : g729 : 6
capabilityTableEntryNumber 3
capability receiveAndTransmitUserInputCapability : dtmf : NULL
capabilityTableEntryNumber 4
capability receiveAndTransmitUserInputCapability : basicString : NULL
capabilityTableEntryNumber 44
capability receiveAndTransmitUserInputCapability : hookflash : NULL
capabilityDescriptorNumber 0
##### 08:10:19.978 || OUTGOING || response : terminalCapabilitySetAck
May 10 08:10:19.978 EDT: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
sequenceNumber 1
##### 08:10:19.978 || INCOMING || response : terminalCapabilitySetAck
May 10 08:10:19.978 EDT: H245 MSC INCOMING PDU ::=
sequenceNumber 1
##### 08:10:19.986 || INCOMING || response : masterSlaveDeterminationAck
May 10 08:10:19.986 EDT: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
decision master : NULL
##### 08:10:19.986 || OUTGOING || response : masterSlaveDeterminationAck
May 10 08:10:19.986 EDT: H245 MSC OUTGOING PDU ::=
decision slave : NULL
##### 08:10:19.994 || OUTGOING || request : openLogicalChannel
May 10 08:10:19.994 EDT: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
forwardLogicalChannelNumber 1
forwardLogicalChannelParameters
dataType audioData : g729 : 2
multiplexParameters h2250LogicalChannelParameters :
sessionID 1
mediaControlChannel unicastAddress : iPAddress :
network '0E3026FC'H
tsapIdentifier 17745
silenceSuppression TRUE
##### 08:10:19.998 || INCOMING || request : openLogicalChannel
May 10 08:10:19.998 EDT: H245 MSC INCOMING PDU ::=
sessionID 1
network '0E302606'H
tsapIdentifier 4001
silenceSuppression FALSE
##### 08:10:20.006 || OUTGOING || response : openLogicalChannelAck
May 10 08:10:20.006 EDT: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
mediaChannel unicastAddress : iPAddress :
network '0E3026FC'H
tsapIdentifier 17744
network '0E3026FC'H
flowControlToZero FALSE
##### 08:10:20.034 || INCOMING || response : openLogicalChannelAck
May 10 08:10:20.034 EDT: H245 MSC INCOMING PDU ::=
sessionID 1
network '0E302629'H
tsapIdentifier 25984
network '0E302629'H
tsapIdentifier 25985
##### 08:10:27.546 || INCOMING || request : closeLogicalChannel
May 10 08:10:27.546 EDT: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : closeLogicalChannel :
source user : NULL
##### 08:10:27.546 || OUTGOING || response : closeLogicalChannelAck
May 10 08:10:27.546 EDT: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : closeLogicalChannelAck :
##### 08:10:27.554 || INCOMING || command : endSessionCommand
May 10 08:10:27.554 EDT: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= command : endSessionCommand : disconnect : NULL
##### 08:10:27.558 || OUTGOING || command : endSessionCommand
May 10 08:10:27.558 EDT: H245 MSC OUTGOING PDU ::=
##### 08:10:27.566 || INCOMING || h323-message-body releaseComplete
May 10 08:10:27.566 EDT: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body releaseComplete :
callIdentifier
h245Tunneling FALSE
##### 08:10:27.594 || OUTGOING || h323-message-body releaseComplete
May 10 08:10:27.594 EDT: H225.0 OUTGOING PDU ::=
h323-uu-pdu
callIdentifier
h245Tunneling FALSE
