cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Swaminathan N on 16-02-2010 08:54:15 AM
I'm trying to integrate my application with Application Gateway. I was also able to properly register(OpenReq/OpenConf) the application with application gateway. But i'm not able to get the heartbeat request from application gateway.
My application listens on IP/Port and handles the TCP request and is an asynchronous application. Communnication happens using Socket over TCP/IP.
Any help is appericiated.
Regards & Thanks,
N. Swaminathan
Subject: RE: Hearbeat Not Received from Application gateway
Replied by: Michael Giberson on 02-06-2010 02:33:49 PM
Heartbeating is a standard mechanism -- but there could be many things that are getting in the way with your implementation.
Cisco Advanced Services has a set of pre-built software integration packages which can be used to integrate external applications.
Standard interfaces include ODBC, Web/XML, WebSphere MQ, as well as a COM-based API/SDK.
These packages are a cost effective option in order to reduce development time and accelerate time to market.
It might be beneficial to review the Advanced Services offerings before building your own Application Gateway.
Details on these integration packages are available in the Application Gateway Protocol Technology Center.
