cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mark Wright on 22-08-2012 01:05:54 PM
I have been able to get https to work from IOS command using copy or more. I have also able to get http gets and posts to work form TCL scripts.
But what I need to get to work from TCL is Secure HTTP (https). I am using a 881-W Router.
The http.tcl file on the router history shows that SSL suport added.
# Rough version history:
# 1.0 Old http_get interface
# 2.0 http:: namespace and http::geturl
# 2.1 Added callbacks to handle arriving data, and timeouts
# 2.2 Added ability to fetch into a channel
# 2.3 Added SSL support, and ability to post from a channel
# This version also cleans up error cases and eliminates the
# "ioerror" status in favor of raising an error
# 2.4 Added -binary option to http::geturl and charset element
# to the state array.
Does anyone have been able to get this to work?
If so do you have an example TCL script using https?
Mark Wright
Subject: RE: Help using Https from TCL scripts on a router 881-w
Replied by: Yaw-Ming Chen on 22-08-2012 04:52:39 PM
Tcl API discussed in this forum is for IVR and voice application, what is your application ?
In here we need to use httpios::geturl  not http::geturl
example:
set token1 [::httpios::geturl $url -query [::httpios::formatQuery testnum $number] -command act_http_callback1]
Whether works for https or not, never try, so really don't know.
Thanks !
Replied by: Mark Wright on 23-08-2012 12:17:49 PM
Yaw-Ming, I am using TCL to configure a cisco 881-W router. Do you know what forum would be the correct one for TCL help on routers?
or do you know where I could get the source for httpios.tcl?
On the router I have I don't have this package.
Mark Wright
Replied by: Yaw-Ming Chen on 23-08-2012 01:11:14 PM
I am sorry to say that this forum may not be able to help you much because API here is not really for your application.
You can try Cisco TAC forum
https://supportforums.cisco.com/index.jspa
Thanks !
