cdnadmin
Community Member
This document was generated from CDN thread
Created by: Aaron Birk on 14-01-2010 08:49:38 PM
So I am having a few problems with a script that had been working fairly well for awhile.  Just recently, there have been two instances of my script that seems like it is hung.  In short, the script accepts a call and the user can enter a 7digit number.  The script then tries to make a call to that 7digit number.  (its used as a front end for MeetMe conferencing)  If the script cannot complete the call, it tries again in 30 seconds.  After 15 minutes, the script is supposed to end the call.  I have this running on two CMM's running 12.4(25b) IOS.  One CMM has had an instance hung since January 7th and the other CMM has one hung from January 13th.  I will include my debugs and show commands at the bottom of my post.  I have tried a couple different ways of ending the session and have had no luck.  I tried, "clear call voice cause 1 id 77E4 (this is the SID of the call)", "call app sess stop id 77E4", "call app sess stop hand meetme (meetme being the name of the script)"  Does anyone else know of any other way of closing this call?
CMM1:
CMM1#sh call app act sess sum
SID  Application Name       Stat Err Cnt    Log Start Time
77E4 meetme                 Y    3          N   Jan 13 09:57:45
7DF5 Default                Y    0          N   Jan 14 12:58:14
7DF6 Default                Y    0          N   Jan 14 12:58:28
7DFD Default                Y    0          N   Jan 14 12:59:40
7E10 Default                Y    0          N   Jan 14 13:01:43
LOGS.....
13294905: Jan 13 09:57:44.306 CST: //135391//TCL :/tcl_PutsObjCmd: Calling - 43028
13294906: Jan 13 09:57:44.310 CST:
13294907: Jan 13 09:57:52.506 CST: //135391//TCL :/tcl_PutsObjCmd: Too few numbers - 1
13294908: Jan 13 09:57:52.506 CST:
13294909: Jan 13 09:57:59.674 CST: //135391//TCL :/tcl_PutsObjCmd: Meeting number 7274482
13294910: Jan 13 09:57:59.674 CST:
13294911: Jan 13 09:58:02.674 CST: //135391//TCL :/tcl_PutsObjCmd:
13294912:          **** act_TerminateSetup
13294920: Jan 13 09:58:42.983 CST: //135391//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
13294921: Jan 13 09:58:42.983 CST: TCL script failure
13294922:  Result:
13294923:                   CallSetup already active on leg
13294924: Jan 13 09:58:42.983 CST:         TCL script failure errorInfo:
13294925:                  CallSetup already active on leg
13294926:     while executing
13294927: "leg setup $destination callInfo leg_incoming
13294928:     (procedure "act_CallSetup" line 16)
13294929:     invoked from within
13294930: "act_CallSetup"
CMM2:
CMM2#sh call app act sess sum
1284 meetme                 Y    19         N   Jan  7 10:02:32
1B6A Default                Y    0          N   Jan 14 10:15:44
1C05 Default                Y    0          N   Jan 14 13:09:36
1C08 Default                Y    0          N   Jan 14 13:10:01
1C19 Default                Y    0          N   Jan 14 13:28:26
LOGS.....
19039: Jan  7 10:02:33.074 CST: //16229//TCL :/tcl_PutsObjCmd: Calling - 7139397700
19040: Jan  7 10:02:33.074 CST:
19043: Jan  7 10:02:46.754 CST: //16229//TCL :/tcl_PutsObjCmd: Meeting number 7241728
19064: Jan  7 10:07:08.750 CST:
19076: Jan  7 10:07:23.950 CST: //16229//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
19077: Jan  7 10:07:23.950 CST: TCL script failure
19078:         Result:
19079:                          CallSetup already active on leg
19080: Jan  7 10:07:23.950 CST:        TCL script failure errorInfo:
19081:                         CallSetup already active on leg
19082:     while executing
19083: "leg setup $destination callInfo leg_incoming
19084:     (procedure "act_CallSetup" line 16)
19085:     invoked from within
19086: "act_CallSetup"
Subject: RE: Help with hung script
Replied by: Yawming Chen on 14-01-2010 10:15:23 PM
Did you recently upgrade IOS ?
looks like it's trying to setup a call leg but it's already active. Without script it's hard to say what went wrong.
You can open a SR on Cisco developer Support.
<a>http://developer.cisco.com/web/devservices</a>]
