cdnadmin
Community Member
This document was generated from CDN thread
Created by: long cao on 01-03-2010 03:27:25 PM
Hi, guys,
I saw a post here talking about how to develop jave code for CVP PROJECT.
it seems that java code has to be developed in a sepreate java project and compiled , then copied to cvp project.
In this way, how can we use breakpoint to debug these java code?
Thanks in advance.
kevin
Subject: RE: How can I debug java code for cvp project using breakpoints?
Replied by: Cun Yong Tan on 02-03-2010 08:24:23 PM
You can debug this the same way you would do debug any java webapp ( VXML Server is just a webapp ).
For instance, I found this just by searching the web: http://it.newinstance.it/2005/10/04/remote-debugging-tomcat-with-eclipse/
Replied by: long cao on 03-03-2010 03:51:31 PM
Thank you very much
