In this short article I show how can you set or change your Voicemail PIN either if you are using an IP Phone, Jabber or Webex with UCM Calling.
- Log in to this URL from your browser while you are on your corporate network: http://<Cisco Unity Connection server>/inbox
- Log in there with your userid and LDAP or local credentials
- Go to the Settings Tab
- That takes you to a new page Select there Passwords > Change PIN
- Create a New PIN
