Resolution
This is how data flows from the Data Gateway (DGW) to the Push-To-Talk (PTT) application server and the TimesTen Data Authority Server (TTDAS) with Data Exchanger (DE):
- The PTT server registers at DE with an application name, and communicates its primary and secondary server name and status with the DE through the getSEDataNotifyManager method.
- The PTT server invokes the getSEDataAccessManager with the same name and password, in order to bind the Ar interface. This allows the PTT server to pull data.
- DE binds the PTT servers.
- DGW publishes an update on the message bus (Sonic broker).
- DE writes into the TTDAS.
- DE publishes the update to the An queue.
- DE reads objects from the An queue.
- DE makes interface validation and calls the PTT server.
Note: The PTT server uses an interface in order bind with DE.
Note: DE uses an inteface in order to read objects from the the An queue.
