TCC_2
Community Member
Resolution
In order to match the Cisco Unity Connection prompts, you need to modify the template:
  1. When you create a new user, you must assign them a template.
    This is under User > User Template.
  2. If you click on the User Template you use for new users, there is an edit
    option.  You want to edit this template.
    Choose Edit > Phone Menu.
  3. In the Phone Menu page, choose Conversation Style.
  4. In the drop-down menu, choose the conversation you want to use.  In order to see what the right one is for a working user, go to the user and edit Phone Menu.  See what style is used , for example, most likely Optional Conversation 1.  If this is it, change this for your template and then all the new users created with this template have this conversation.
