TCC_2
Level 10
Level 10
Resolution
To configure the Digital Signal Processor (DSP) farm for conferencing and transcoding services, perform this procedure:
Note: First, issue the show voice dsp command to determine that there are enough DSPs available for conferencing and transcoding services.
  1. Issue the enable command.
  2. Issue the configure terminal command.
  3. Issue the dspfarm confbridge maximum sessions number command.
  4. Issue the dspfarm      transcoder maximum sessions number command.
  5. Issue the dspfarm command.
  6. Exit the Command Line Interface (CLI).
For more details, refer to Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers.
