TCC_2
Level 10
Level 10
Resolution
Refer to these documents:
Verifiy these things:
  • The Media Gateway Control Protocol (MGCP) gateway is registered properly.
  • The route group has the correct MGCP gateway assigned to it.
  • The route list has the correct route group assigned to it.
  • The CSS of the MGCP gateway contains the partition of the phones.
  • After you make any configuration changes on the MGCP gateway, issue these two global commands in sequence on the MGCP gateway for the changes to take effect:
For MGCP gateway registration issues, refer the document
