TCC_2
Level 10
Level 10
Resolution
To confirm whether  Voice Activity Detection (VAD) is enabled on a call-by-call basis, perform these steps:
  1. Make a call.
  2. Issue the show call active (brief) command.
  3. Check the values for the Voice over IP (VoIP) call leg.
To disable VAD, perform these steps:
  1. Confirm that the correct dial peer is being matched.
  2. Issue the no vad command under the VoIP dial peer.
