TCC_2
Level 10
Level 10
Resolution
Perform a fresh installation on the subscriber server once the publisher has been upgraded.
Note: During the operating system installation, choose the New Installation or Server Replacement option. Do not check the I am recovering a system from backup check box.
For more information on the procedure for replacing subscriber servers during an upgrade to Cisco CallManager 3.3, refer to Using Cisco CallManager Upgrade Assistant Utility 3.3(3).
