cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Pipat Tipvapee on 22-04-2012 11:59:12 PM
Ref.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user/guide/assistant/7xcucugasst010.html
When I try to login Unity Connection Assistant Web Tool with Administration account, It show msg
"This user account does not have a mailbox and cannot sign in to the Cisco
Personal Communications Assistant. To use the Cisco PCA, you must have an
account with a mailbox."</td>
How to create username and password to login URL https://<unity_address>/ciscopca
Subject: RE: How to login to Cisco Unity Connection Assistant Web Tool?
Replied by: Adrienne Moherek on 13-08-2013 02:55:31 PM
  1. Login to Cisco Unity Connection as admin
  2. Create a new user
  3. For User Type, select User with Mailbox
  4. Fill in all other fields
  5. Set the user's password
  6. Login to Unity Connection Assistant Web Tool with your new user credentials.
