06-22-2009 03:36 PM - edited 03-12-2019 08:29 AM
Perform these procedures to resolve general GroudStart (GS) issues:
dial-peer voice X pots
destination-pattern 9T
port X/Y/Z
By issuing the csim start hidden command, you can send calls to whichever real world E.164 number is desired to see if it is possible to correctly go off hook from the router to the Public Switched Telephone Network (PSTN), send digits, and complete a call to the proper destination phone. Modify the POTS dial-peer appropriately to account for long distance access codes and other prefixed digits as necessary.
Issue the debug vpm all undebug vpm dsp command. Then issue the csim command to send an outbound call. Compare the debugs with this output for a successful FXOGS outbound call:
*Mar 1 04:33:08.838: [1/1:1(1), FXOGS_ONHOOK, E_HTSP_SETUP_REQ] fxogs_onhook_setup[Foreign Exchange Office
1/1:1(1)] set signal state = 0x0
*Mar 1 04:33:08.838: htsp_timer - 10000 msec
*Mar 1 04:33:09.214: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x4 timestamp=40280 systime=1638921
*Mar 1 04:33:09.218: [1/1:1(1), FXOGS_WAIT_TIP_GROUND, E_DSP_SIG_0100] fxogs_start_dial
*Mar 1 04:33:09.218: htsp_timer_stop [Foreign Exchange Office 1/1:1(1)] set signal state = 0xC
*Mar 1 04:33:09.218: htsp_timer - 1000 msec
*Mar 1 04:33:10.218: [1/1:1(1), FXOGS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER] fxogs_wait_dial_timer htsp_dial
*Mar 1 04:33:12.226: [1/1:1(1), FXOGS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE] fxogs_wait_dial_donehtsp_connect:
no_offhook 0htsp_alert
*Mar 1 04:33:12.226: [1/1:1(1), FXOGS_OFFHOOK, E_HTSP_CONNECT] fxogs_proc_voice
*Mar 1 04:33:12.478: [1/1:1(1), FXOGS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]
*Mar 1 04:33:12.514: [1/1:1(1), FXOGS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]
*Mar 1 04:33:12.526: [1/1:1(1), FXOGS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]
#Call connects now and is answered. No signaling is reported (no answer supervision for groundstart)
#Call disconnected from VOIP leg below vdtl-2600-6d#htsp_release_req: cause 16, no_onhook 0
*Mar 1 04:33:22.590: [1/1:1(1), FXOGS_OFFHOOK, E_HTSP_RELEASE_REQ] fxogs_offhook_release
*Mar 1 04:33:22.590: htsp_timer_stop
*Mar 1 04:33:22.590: htsp_timer_stop2 [Foreign Exchange Office 1/1:1(1)] set signal state = 0x4
*Mar 1 04:33:22.590: htsp_timer - 2000 msec
*Mar 1 04:33:22.778: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=53840 systime=1640278
*Mar 1 04:33:22.778: [1/1:1(1), FXOGS_WAIT_ONHOOK, E_DSP_SIG_1100] fxogs_waitonhook_onhook
*Mar 1 04:33:22.778: htsp_timer_stop
*Mar 1 04:33:22.778: htsp_timer - 2000 msec
*Mar 1 04:33:22.782: vnm_dsprm_close_cleanup
*Mar 1 04:33:24.778: [1/1:1(1), FXOGS_GUARD_OUT, E_HTSP_EVENT_TIMER]
If the call rings the desired phone, the issue is resolved. If not, go to the next step.
The easiest way to quickly reverse the polarity on an RJ-11 line is to use an RJ-45 cable extender and a short span of two-wire RJ-11 crossover cable to insert inline between the existing cabling and the voice port. Such a short crossover RJ-11 cable can either be crimped by the tester, or it can be commonly retrieved from the collection of accessories from store-bought analog phones, which often come with such a cable. Two-wire RJ-11 cabling is preferred for both testing and production connections to Foreign Exchange Station (FXS) and FXO voice ports, with just the conductors on pins two and three connected.
Ensure that the chassis ground reference and the electrical ground reference that the CO provides for the GS line are the same.
The aim of connecting the FXOGS voice port to an FXSGS voice port is to verify that one voice gateway can signal the other over the connection and draw dial tone from the peer gateway. This is a complete testing scenario:
(x888)PhnA---FXSLS[ RtrA ]FXOGS====FXSGS[ RtrB ]FXSLS---PhnB(x999)
(1/0/0) (2/0/0) (2/0/0) (1/0/0)
RtrA RtrB
voice-port 1/0/0 voice-port 1/0/0
voice-port 2/0/0 voice-port 2/0/0
signal GroundStart signal GroundStart
dial-peer voice 888 pots dial-peer voice 888 pots
destination-pattern 888 destination-pattern 888
port 1/0/0 port 2/0/0
dial-peer voice 999 pots dial-peer voice 999 pots
destination-pattern 999 destination-pattern 999
port 2/0/0 port 1/0/0
In this scenario, a user can pick up an analog phone to get dial tone from the local router, dial the far-end extension to go off hook on the GS line, hear dial tone from the peer gateway, then dial the far-end extension once again to complete the call to the far-end phone. If this works correctly in both directions, the FXO voice port is functioning as expected. Make sure to check for two-way audio.
