cdnadmin
Community Member
This document was generated from CDN thread
Created by: Sou Vang on 07-07-2009 05:37:15 PM
I have a list of device names where I want to use to retrieve the ip addresses using RIS.  I already have the wsdl generated to java classes and will be using that.
I'm stuck on creating the header section of the message.  I don't see a AstHeader class where I can set that up and the RISService/RISServiceLocator does not have a userName/userPassword method where I can setup the credentials.
Any help or example of this in java will be greatly appreciated.
Sou
Subject: RE: How to retrieve IP Address using RIS in java
Replied by: David Staudt on 07-07-2009 07:09:29 PM
Have you seen this how-to on the AXL wiki: http://developer.cisco.com/web/sxml/wikidocs?src=/wiki/display/SXML/IP+Address+Report
I believe the Axis code handles the required SOAPAction header.
Replied by: Sou Vang on 07-07-2009 08:40:06 PM
Thank you very much...This is what I have been looking for.
Sou
