cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Rajesh C Mundackal on 09-03-2010 11:54:45 AM
Hi, I am new to this. Is it possible to setup call restriction to a line using AXL? If so, how?
Subject: RE: How to setup call restriction for a Phone Line
Replied by: David Staudt on 09-03-2010 12:37:23 PM
Can you describe what you mean by 'call restriction?'  If you mean to restrict calling to only certain destinations, then: yes, you can configure a restrictive Calling Search Space on UCM and assign that to a phone or to a specific line via AXL <updatePhone> or <updateLine> request.
Replied by: Rajesh C Mundackal on 09-03-2010 02:05:29 PM
What I mean is to restrict the user to use the phone with "Local Calling", "Local Calling and Mobile", "Domestic Calling", "International" so on
Replied by: David Staudt on 09-03-2010 03:07:48 PM
Ok, then CSS is what you want to look at manipulating.  Read up on UCM CSS features, configuration and management.  In its simplest incarnation, you will configure the partitions/CSS's on UCM per your  requirements, and then use AXL <updateLine> or <updatePhone> to modify a phone's active CSS.  I.e. switch from the '911 only' CSS to the 'Local dialing' CSS.
Replied by: Rajesh C Mundackal on 09-03-2010 06:09:14 PM
Could you please send me a sample AXL soap ?
Replied by: Eduardo G. Cruz on 30-03-2010 08:15:56 PM
It was resolved ? I have the same problem.
