Core Issue
The user is unable to register the Inno Media phone, even after commenting out this information from the dsedge.cfg file and re-loading the new configuration, then committing it again.
!- load-xcl -s dsedge_auth -f dsedge_auth.xcl
!- load-xcl -s dsedge_auth_action -f dsedge_auth_action.xcl
Resolution
To turn off authentication, perform these steps:
Log in into Edge Proxy by issuing this command:
telnet localhost < 8070 >
To change context to xcl, issue this command:
dsedge-EP>context xcl
From the Command Line Interface (CLI), issue this command:
dsedge-EP[xcl]> xcl-cli-params -n authentication -v false
To save the changes to the dsedge.cfg file, issue this command:
commit < version-number >
To verify changes issue this command:
view xcl-cli-params
