cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Trevor Berceau on 07-10-2008 07:56:11 PM
I am trying to automate login to a phone at a desk when a user logs into the workstation. I can find what phone it is, but I don't know where to send the user information to log in.
Is there a web service I can call? Is there somewhere I need to send an HTTP post to? If so (in either case), what directory would it be located in on the phone server?
Trevor
Subject: Re: How to Use Extension Mobility?
Replied by: Stephan Steiner on 09-10-2008 08:42:53 AM
Yes there's a webservice.. the methods and the service url are explained in the extension mobility section of the xml developer guide: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/devguide/7_0_1/ccmdvCh3.html
Subject: RE: How to Use Extension Mobility?
Replied by: Simon Machielse on 28-10-2010 06:15:20 PM
there are alreayd several application developed for this function. try google and enter cisco single sign on, this should point you to the right direction. i came across a product called ALM a couple of months ago, look for this using google.
