Resolution
The Performance Monitor can be used to monitor and report on Cisco Media Gateway Control Protocol (MGCP) gateways. It also shows how to reset an MGCP gateway. If required, it shows how to delete an MGCP gateway.
For more information on how to set up the Performance Monitor, refer to the Set Up and Use Performance Monitor section of Monitor, Reset, and Delete MGCP Gateways for Cisco CallManager.
Another Cisco certified product is Vivinet Manager from NetIQ. In addition to MGCP gateways, this product monitors other Cisco CallManager related components.
For more information, refer to NetIQ.
