Resolution
To verify the connectivity between DGW and MPDS, perform these steps:
- Log in to DGW.
- Issue the telnet localhost <8070> command.
- Change context to data-access by issuing the dsdgw> context data-access command.
- Issue the dsdgw[data-access]> db-status command from the Command Line Interface (CLI).
This is a sample output:
db-status -i 192.168.XX.XX -p 1521 -s online -r 2 -u stand-by
db-status -i 192.168.XX.XX -p 1521 -s online -r 1 -u in-use
Note: One MPDS is always in-use, and another should be on standby. If you see any of the db-status offline, contact Cisco Technical Support.
