Paul Varghese
Community Member
The keyboard shortcuts that are configured for Cisco Unified CallManager Attendant Console allow you to perform call-control tasks and navigate the attendant console user interface efficiently. Use the Table below as a guide for performing call-control tasks by using keyboard shortcuts.
Desired result
System Default Shortcut
Answer Call
Ctrl + A
Place Call
Ctrl + D
End Call
Ctrl + H
Place Call on Hold
Ctrl + L
Retrieve Call from Hold (Resume)
Ctrl + L
Park a Call
Ctrl + P
Revert a Parked Call
Ctrl + P
Transfer
Ctrl + X
Consult Transfer
Ctrl + T
Direct Transfer
Ctrl + R
Join Calls
Ctrl + J
Conference Call
Ctrl + N
Forward a Call to Voice Mail
Ctrl + O
Using Dials Digits
Ctrl + S
The attendant console automatically sets the default keyboard shortcutIf you want to change the system default shortcuts, enter the keyboard shortcut that you configured in the Shortcut Configured By Attendant column.
Keyboard Shortcuts for Navigation
Desired Result
System Shortcut
Move from one window to another
Ctrl + F6
Move to the Call Control window
Ctrl + Shift + L
Move to the Broadcast Calls window
Ctrl + Shift + B
Move to the Directory window
Ctrl + Shift + D
Move to the Parked Calls window
Ctrl + Shift + P
Move to the Speed Dials window
Ctrl + Shift + S
Move from cell to cell in a table
Tab
Move to the next row in a table
Down Arrow
Move to the previous row in a table
Up Arrow
Move to areas of a window, including the scroll bars (if any) Note At times, pressing Ctrl + Tab performs the same function as pressing Tab. After you navigate to the scrollbar in the Dial Pad window, you must press Tab to navigate to the Enter Number field.
Ctrl + Tab
Scroll down Before you scroll down in the window, make sure that you put the focus on the scroll bar. Press Ctrl + Tab until you navigate to the scroll bar.
Down Arrow
Scroll up Note Before you scroll up in the window, make sure that you put the focus on the scroll bar. Press Ctrl + Tab until you navigate to the scroll bar.
Up Arrow
Move to the next tab Note Before you move to the next tab in the window, make sure that you put the focus on a tab. Press Ctrl + Tab until you navigate to the tabs.
Right Arrow
Move to the previous tab Note Before you move to the previous tab in the window, make sure that you put the focus on a tab. Press Ctrl + Tab until you navigate to the tabs.
Left Arrow
Moves to components of a given window. You may need to press Ctrl + Tab to navigate to different components within a window.
Tab
Activates buttons
Space bar
Move to the Department combo box in the Dial Pad
Alt + C
Move to the Directory table in the Dial Pad
Alt + T
Move to the First Name field in the Dial Pad
Alt + F
Move to the Last Name field in the Dial Pad
Alt + L
Move to the Number field in the Dial Pad
Alt + N
