cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Manuel Michel on 15-10-2012 07:44:04 AM
Is there a way to open links in the link portlet in a new window? currently, all links to external / internal destinations are opened in the same window. This can be anoying if users link to external pages, they would leave WxS. In the bookmarks portlet, all links are opened in a new window, but the customer prefers to have internal / external links in the same destination (link portlet)
Manuel
Subject: RE: Links Portlet Enhancement
Replied by: Ratnadeep Ray on 16-10-2012 05:45:51 AM
Hi Manuel,
Suppose by default they make the system such that the links open in a new window/tab, then many many NOT like that either. I feel one easy way to handle this issue would be to open the link in a new tab/window.
What do you say about this?
Ratnadeep.
Replied by: Manuel Michel on 16-10-2012 06:14:18 AM
Yes, I've told the customer the same, but he requested to have a admin controllable option for this, e.g., like a checkbox when creating a new link in the portlet which says #Open in a new Window'. Our goal is, to make it as easy as possible for users to use WxS, avoiding that users need to think always about 'oh, I need to open this with right click' instead of simply click the link.
Manuel
Replied by: Ratnadeep Ray on 17-10-2012 01:16:44 AM
Hi Manuel,
See if the user is creating a post, then he already has got the option to direct the page to open in a new tab/window. He can do so by going to the HTML source code. However for the links mentioned in the Activities bar, we can have an enhancement request.
Ratnadeep.
Replied by: Manuel Michel on 17-10-2012 04:10:10 AM
I never spoke about a post, how do you came up with that? I speak about the links portlet where you can either link to a post or to an external URL, which should be opened in a new window. I'm still not sure you understand correctly what I mean?
Replied by: Ratnadeep Ray on 17-10-2012 06:13:36 AM
Hi Manuel,
Thanks for clarifying the matter. I have raised the enhancement request "CSCuc73543" for this.
Hope this helps.
Ratnadeep.
