on 01-24-2014 04:37 PM
Marko Laurits:Thanks for the detailed answer!
You said that there is a slight possibility that CEC may be implemented in future. Would the implementation require new hardware or could it be done in software?
Marko Laurits:
I wonder that if you can't switch off most monitors via HDMI why didn't you put DVI-I output for both monitors at C60?
Marko Laurits:
How did you solve the sleep problem at MXP profiles?
I understand that typical Nec / Samsung displays are used there?
